Journal articles
Regularity of set-valued maps and their selections through set differences. Part 2: One-sided Lipschitz properties
Abstract : We introduce one-sided Lipschitz (OSL) conditions of set-valued maps with respect to given set differences. The existence of selections of such maps that pass through any point of their graphs and inherit uniformly their OSL constants is studied. We show that the OSL property of a convex-valued set-valued map with respect to the Demyanov difference with a given constant is characterized by the same property of the generalized Steiner selections. We prove that an univariate OSL map with compact images in R1 has OSL selections with the same OSL constant. For such a multifunction which is OSL with respect to the metric difference, one-sided Lipschitz metric selections exist through every point of its graph with the same OSL constant.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01067207
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Tuesday, September 23, 2014 - 11:05:39 AM
Last modification on : Friday, October 13, 2017 - 5:08:16 PM
Identifiers
  • HAL Id : hal-01067207, version 1
Collections
Citation
Robert Baier, Elza Farkhi. Regularity of set-valued maps and their selections through set differences. Part 2: One-sided Lipschitz properties. Serdica Mathematical Journal, Bulgarian Academy of Sciences, 2013, Special volume dedicated to the 65th Anniversary of Professor Asen L. Dontchev and to the 60th Anniversary Professor Vladimir M. Veliov, 39 (3-4), pp.391-422. ⟨hal-01067207⟩
Share
Metrics
Record views
54
