Polygon mesh repairing: An application perspective, ACM Comput. Surv, vol.45, issue.15, pp.1-1533, 2013. ,
Conformal flattening by curvature prescription and metric scaling, Computer Graphics Forum, vol.27, issue.2, pp.449-458, 2008. ,
Automatic restoration of polygon models, ACM Trans. Graph, vol.24, issue.4, pp.1332-1352, 2005. ,
Mixedinteger quadrangulation, Proc. SIGGRAPH 2009, pp.1-7710, 2009. ,
Integer-grid maps for reliable quad meshing, Proc. SIGGRAPH 2013, pp.1-9812, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00862648
Quad-Mesh Generation and Processing: A Survey, Computer Graphics Forum, vol.32, issue.6, pp.51-76, 2013. ,
Interactive design of quad layouts using elastica strips, Proc. SIGGRAPH Asia 2014, 2014. ,
Quad layout embedding via aligned parameterization, Computer Graphics Forum, 2014. ,
Dual loops meshing: quality quad layouts on manifolds, ACM Trans. Graph, vol.31, issue.110, pp.1-11011, 2012. ,
Restricted delaunay triangulations and normal cycle, Proceedings of the nineteenth annual symposium on Computational geometry, pp.312-321, 2003. ,
Trivial connections on discrete surfaces, Computer Graphics Forum (SGP), vol.29, issue.5, pp.1525-1533, 2010. ,
Robust fairing via conformal curvature flow, ACM Trans. Graph, vol.32, issue.61, pp.1-6110, 2013. ,
Implicit fairing of irregular meshes using diffusion and curvature flow, Proc. SIGGRAPH '99, pp.317-324, 1999. ,
Designing N -PolyVector fields with complex polynomials, Computer Graphics Forum, vol.33, issue.5, pp.1-11, 2014. ,
QEx: Robust quad mesh extraction, Proc. SIGGRAPH Asia 2013, pp.1-16810, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00815814
Controlled simplification of genus for polygonal models, Visualization '97., Proceedings, pp.403-410, 1997. ,
Topological noise removal, Graphics Interface Proceedings, pp.19-26, 2001. ,
Illustrating smooth surfaces, Proc. SIGGRAPH '00, pp.517-526, 2000. ,
Globally optimal direction fields, ACM Transactions on Graphics, vol.32, issue.4, pp.1-5910, 2013. ,
DOI : 10.1145/2461912.2462005
Anisotropic quadrangulation, Computer Aided Geometric Design, vol.28, p.8, 2011. ,
Quadcover -surface parameterization using branched coverings, Computer Graphics Forum, vol.26, issue.3, pp.375-384, 2007. ,
Metric-driven RoSy field design and remeshing, IEEE Trans. Vis. Comput. Graph, pp.95-108, 2010. ,
Representing higher-order singularities in vector fields on piecewise linear surfaces. Visualization and Computer Graphics, IEEE Transactions on, vol.12, issue.5, pp.1315-1322, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00105598
Meshless quadrangulation by global parameterization, Computers & Graphics, vol.35, issue.5, pp.992-1000, 2011. ,
On surface normal and gaussian curvature approximations given data sampled from a smooth surface, Computer Aided Geometric Design, vol.17, issue.6, pp.521-543, 2000. ,
Global parametrization by incremental flattening, Proc. SIGGRAPH 2012, pp.1-10911, 2012. ,
Feature-aligned T-meshes, Proc. SIGGRAPH 2010, pp.1-11711, 2010. ,
Robust field-aligned global parametrization, Proc. SIGGRAPH 2014, pp.1-13514, 2014. ,
Rotational symmetry field design on surfaces, ACM Trans. Graph, vol.26, issue.3, p.55, 2007. ,
Fields on symmetric surfaces, ACM Trans. Graph, vol.31, issue.111, pp.1-11112, 2012. ,
Frame fields: Anisotropic and nonorthogonal cross fields, Proc. SIGGRAPH 2014, pp.1-13411, 2014. ,
Global parametrization of range image sets, Proceedings of SIGGRAPH Asia, 2006. ,
Nsymmetry direction field design, ACM Trans. Graph, vol.27, issue.10, pp.1-1013, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00331900
Geometry-aware direction field processing, ACM Trans. Graph, vol.29, issue.1, pp.1-111, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00547716
Conformal equivalence of triangle meshes, ACM Trans. Graph, vol.27, issue.77, pp.1-7711, 2008. ,
Simple quad domains for field aligned mesh parametrization, Proc. SIGGRAPH Asia, pp.1-14212, 2011. ,
Hatching for motion picture production, Computer Graphics Forum, vol.30, issue.2, pp.533-542, 2011. ,
Topology repair of solid models using skeletons. Visualization and Computer Graphics, IEEE Transactions on, vol.13, issue.4, pp.675-685, 2007. ,
