A SEIR model for control of infectious diseases with constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2014
Optimal control can be of help to test and compare different vaccination strategies of a certain disease. In this paper we propose the introduction of constraints involving state variables on an optimal control problem applied to a compartmental SEIR (Susceptible. Exposed, Infectious and Recovered) model. We study the solution of such problems when mixed state control constraints are used to impose upper bounds on the available vaccines at each instant of time. We also explore the possibility of imposing upper bounds on the number of susceptible individuals with and without limitations on the number of vaccines available. In the case of mere mixed constraints a numerical and analytical study is conducted while in the other two situations only numerical results are presented.
hal-01067316 , version 1 (23-09-2014)
Md. Haider Ali Biswas, Luis Tiago Paiva, Maria Do Rosário de Pinho. A SEIR model for control of infectious diseases with constraints. Mathematical Biosciences and Engineering, 2014, 11 (4), pp.761 - 784. ⟨10.3934/mbe.2014.11.761⟩. ⟨hal-01067316⟩
Collections
SADCO TDS-MACS
312 Consultations
0 Téléchargements
