Abstract : In the context of remote sensing image classification, Markov random fields (MRFs) have been used to combine both spectral and contextual information. The MRFs use a smoothing parameter to balance the contribution of the spectral versus spatial energies, which is often defined empirically. This paper proposes a framework to estimate the smoothing parameter using the probability estimates from support vector machines and the spatial class co-occurrence distribution. Furthermore, we construct a spatially weighted parameter to preserve the edges by using seven different edge detectors. The performance of the proposed methods is evaluated on two hyperspectral datasets recorded by the AVIRIS and ROSIS and a simulated ALOS PALSAR image. The experimental results demonstrated that the estimated smoothing parameter is optimal and produces a classified map with high accuracy. Moreover, we found that the Canny-based edge probability map preserved the contours better than others.
https://hal.inria.fr/hal-01068242
Contributor : Yuliya Tarabalka <>
Submitted on : Thursday, September 25, 2014 - 11:39:46 AM Last modification on : Saturday, January 27, 2018 - 1:31:40 AM Long-term archiving on: : Friday, December 26, 2014 - 10:31:50 AM
Hossein Aghighi, John Trinder, Ke Wang, Yuliya Tarabalka, Samsung Lim. Smoothing parameter estimation for Markov random field classification of non-Gaussian distribution image. ISPRS TC VII Symposium, Sep 2014, Istanbul, Turkey. ⟨hal-01068242⟩
