An Efficient Policy Iteration Algorithm for Dynamic Programming Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2015
We present an accelerated algorithm for the solution of static Hamilton-Jacobi-Bellman equations related to optimal control problems. Our scheme is based on a classic policy iteration procedure, which is known to have superlinear convergence in many relevant cases provided the initial guess is sufficiently close to the solution. In many cases, this limitation degenerates into a behavior similar to a value iteration method, with an increased computation time. The new scheme circumvents this problem by combining the advantages of both algorithms with an efficient coupling. The method starts with a value iteration phase and then switches to a policy iteration procedure when a certain error threshold is reached. A delicate point is to determine this threshold in order to avoid cumbersome computation with the value iteration and, at the same time, to be reasonably sure that the policy iteration method will finally converge to the optimal solution. We analyze the methods and efficient coupling in a number of examples in dimension two, three and four illustrating its properties.
hal-01068295 , version 1 (25-09-2014)
Alessandro Alla, Maurizio Falcone, Dante Kalise. An Efficient Policy Iteration Algorithm for Dynamic Programming Equations. SIAM Journal on Scientific Computing, 2015, 37 (1), pp.A181-A200. ⟨10.1137/130932284⟩. ⟨hal-01068295⟩
101 Consultations
0 Téléchargements
