Homogeneous Resonance & Asymptotic Stability for Homogeneous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
This paper surveys existing necessary conditions, and gives new conditions based on homogeneous resonance, for a homogeneous system to admit a homogeneous (of correct order) continuous, asymptotically stabilizing, state, feedback control. Such conditions are basic in utilizing high order, homogeneous, approximations of non-linear systems to construct asymptotically stabilizing feedback controls when linear approximations of the nonlinear system are not locally controllable. For a class of three dimensional, homogeneous, locally controllable, systems, we determine at which resonance values they can be stabilized.
asfc.pdf (277.82 Ko) Télécharger le fichier
hal-01068325 , version 1 (25-09-2014)
  • HAL Id : hal-01068325 , version 1
Henry Hermes, Matthias Kawski, Fabio Ancona. Homogeneous Resonance & Asymptotic Stability for Homogeneous Systems. 2014. ⟨hal-01068325⟩
Collections
SADCO TDS-MACS
136 Consultations
124 Téléchargements
