The value function of an asymptotic exit-time optimal control problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Differential Equations and Applications Année : 2014
We consider a class of exit--time control problems for nonlinear systems with a nonnegative vanishing Lagrangian. In general, the associated PDE may have multiple solutions, and known regularity and stability properties do not hold. In this paper we obtain such properties and a uniqueness result under some explicit sufficient conditions. We briefly investigate also the infinite horizon problem.
hal-01068344 , version 1 (25-09-2014)
Monica Motta, Caterina Sartori. The value function of an asymptotic exit-time optimal control problem. Nonlinear Differential Equations and Applications, 2014, ⟨10.1007/s00030-014-0274-1⟩. ⟨hal-01068344⟩
Collections
SADCO TDS-MACS
47 Consultations
0 Téléchargements
