A modeling and code generation framework for critical embedded systems design: From Simulink down to VHDL and Ada/C code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mickael Lanoe
  • Fonction : Auteur
  • PersonId : 933485
Bordin Matteo
  • Fonction : Auteur
Dominique Heller
  • Fonction : Auteur
  • PersonId : 929408
Cyrille Chavet
Philippe Coussy
The P project gathers industrial and academic partners to address the issue of a modeling approach and automatic code generation for critical embedded systems. Works target the definition of an open design flow which integrates qualified tools to produce both hardware and software implementations. This paper introduces the project through two code generators that allow generating Ada, C and VHDL from Simulink. Application of the design flow to two industrial case studies is finally presented.
Fichier non déposé
hal-01069265 , version 1 (29-09-2014)
  • HAL Id : hal-01069265 , version 1
Mickael Lanoe, Bordin Matteo, Dominique Heller, Cyrille Chavet, Philippe Coussy. A modeling and code generation framework for critical embedded systems design: From Simulink down to VHDL and Ada/C code. 21st IEEE International Conference on Electronics Circuits and Systems, Dec 2014, Marseille, France. ⟨hal-01069265⟩
316 Consultations
0 Téléchargements
