Partitioning and Dynamic Load Balancing for the Numerical Solution of Partial Differential Equations, Lecture Notes in Computational Science and Engineering, vol.51, pp.55-88, 2006. ,
DOI : 10.1007/3-540-31619-1_2
Computers and Intractibility: A Guide to the Theory of NP-Completeness, 1979. ,
Think Locally, Act Globally: Highly Balanced Graph Partitioning, Proceedings of the 12th International Symposium on Experimental Algorithms (SEA'13), ser. LNCS, pp.164-175, 2013. ,
DOI : 10.1007/978-3-642-38527-8_16
A new flexible coupler for earth system modeling developed for CCSM4 and CESM1, International Journal of High Performance Computing Applications, vol.26, issue.1, pp.31-42, 2012. ,
DOI : 10.1177/1094342011428141
Coupling LES, radiation and structure in gas turbine simulations, Proceedings of the Summer Program, 2010. ,
Ten organising principles for coupling in multiphysics and multiscale models, ANZIAM Journal, vol.48, pp.1090-1111, 2009. ,
DOI : 10.21914/anziamj.v48i0.138
The oasis3 coupler: a european climate modelling community software, Journal of Geosci. Model Dev, pp.373-388, 2013. ,
Open-palm: an open source dynamic parallel coupler, IV International Conference on Computational Methods for Coupled Problems in Science and Engineering, 2011. ,
Comparisons of coupling strategies for massively parallel conjugate heat transfer with large eddy simulation, IV International Conference on Computational Methods for Coupled Problems in Science and Engineering, 2011. ,
A multilevel algorithm for partitioning graphs, Proceedings of the 1995 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '95, 1995. ,
DOI : 10.1145/224170.224228
A Fast and High Quality Multilevel Scheme for Partitioning Irregular Graphs, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.359-392, 1998. ,
DOI : 10.1137/S1064827595287997
Dynamic load balancing with a spectral bisection algorithm for the constrained graph partitioning problem, High-Performance Computing and Networking, ser. Lecture Notes in Computer Science, pp.392-397, 1995. ,
DOI : 10.1007/BFb0046658
Greedy algorithms for k-way graph partitioning, the 6th international conference on advanced computing, 1998. ,
A linear-time heuristic for improving network partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
Multilevel Algorithms for Multi-Constraint Graph Partitioning, Proceedings of the IEEE/ACM SC98 Conference, pp.1-13, 1998. ,
DOI : 10.1109/SC.1998.10018
Multiphase mesh partitioning, Applied Mathematical Modelling, vol.25, issue.2, pp.123-140, 2000. ,
DOI : 10.1016/S0307-904X(00)00041-X
Computational performance of ultra-high-resolution capability in the Community Earth System Model, International Journal of High Performance Computing Applications, vol.26, issue.1, pp.5-16, 2012. ,
DOI : 10.1177/1094342012436965
Graph partitioning models for parallel computing, Parallel Computing, vol.26, issue.12, pp.1519-1534, 2000. ,
DOI : 10.1016/S0167-8191(00)00048-X
Graph Repartitioning with both Dynamic Load and Dynamic Processor Allocation, International Conference on Parallel Computing -ParCo2013, ser. Advances of Parallel Computing, pp.243-252, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00857881
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
Multilevel Diffusion Schemes for Repartitioning of Adaptive Meshes, Journal of Parallel and Distributed Computing, vol.47, issue.2, pp.109-124, 1997. ,
DOI : 10.1006/jpdc.1997.1410
Wavefront diffusion and LMSR: Algorithms for dynamic repartitioning of adaptive meshes, IEEE Trans. Parallel Distrib. Syst, vol.12, issue.5, pp.451-466, 2001. ,
Adaptive decomposition and remapping algorithms for object-space-parallel direct volume rendering of unstructured grids, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.77-99, 2007. ,
DOI : 10.1016/j.jpdc.2006.05.005
A repartitioning hypergraph model for dynamic load balancing, Journal of Parallel and Distributed Computing, vol.69, issue.8, pp.711-724, 2009. ,
DOI : 10.1016/j.jpdc.2009.04.011
Dynamic load-balancing with variable number of processors based on graph repartitioning, 2012 19th International Conference on High Performance Computing, p.2012, 2012. ,
DOI : 10.1109/HiPC.2012.6507501
URL : https://hal.archives-ouvertes.fr/hal-00722731
Multi-level direct K-way hypergraph partitioning with multiple constraints and fixed vertices, Equilibrage de charge dynamique avec un nombre variable de processeurs basé sur des méthodes de partitionnement de graphe, pp.609-625, 2008. ,
DOI : 10.1016/j.jpdc.2007.09.006
URL : https://hal.archives-ouvertes.fr/hal-00803479
Parallel multilevel k-way partitioning scheme for irregular graphs, Proceedings of the 1996 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '96, pp.96-129, 1998. ,
DOI : 10.1145/369028.369103
