Approximate classification via earthmover metrics, SODA, 2004. ,
An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, 2004. ,
Markov random fields with efficient approximations, Proceedings. 1998 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No.98CB36231), 1998. ,
DOI : 10.1109/CVPR.1998.698673
Fast approximate energy minimization via graph cuts, ICCV, 1999. ,
DOI : 10.1109/iccv.1999.791245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
Approximation algorithms for the metric labeling problem via a new linear programming formulation, SODA, 2001. ,
Transforming an arbitrary minsum problem into a binary one, 2006. ,
Fixing max-product: Convergent message passing algorithms for MAP LP-relaxations, NIPS, 2007. ,
A constant factor approximation algorithm for a class of classification problems, Proceedings of the thirty-second annual ACM symposium on Theory of computing , STOC '00, 2000. ,
DOI : 10.1145/335305.335397
Convergent message-passing algorithms for inference over general graphs with convex free energy, UAI, 2008. ,
Approximation algorithms for classification problems with pairwise relationships: Metric labeling and Markov random fields, STOC, 1999. ,
Convergent Tree-Reweighted Message Passing for Energy Minimization, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.10, 2006. ,
DOI : 10.1109/TPAMI.2006.200
MRF Optimization via Dual Decomposition: Message-Passing Revisited, 2007 IEEE 11th International Conference on Computer Vision, 2007. ,
DOI : 10.1109/ICCV.2007.4408890
The partial constraint satisfaction problem: Facets and lifting theorems, Operations Research Letters, vol.23, issue.3-5, 1998. ,
DOI : 10.1016/S0167-6377(98)00043-1
MAP estimation of semi-metric MRFs via hierarchical graph cuts, UAI, 2009. ,
Improved moves for truncated convex models, NIPS, 2008. ,
Message-passing for graph-structured linear programs, Proceedings of the 25th international conference on Machine learning, ICML '08, 2008. ,
DOI : 10.1145/1390156.1390257
Syntactic analysis of two-dimensional visual signals in noisy conditions, Kibernetika, 1976. ,
A Comparative Study of Energy Minimization Methods for Markov Random Fields with Smoothness-Based Priors, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.6, 2008. ,
DOI : 10.1109/TPAMI.2007.70844
Dynamic tree block coordinate ascent, ICML, 2011. ,
Efficient graph-based energy minimization methods in computer vision, 1999. ,
Graph Cut Based Optimization for MRFs with Truncated Convex Priors, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2007. ,
DOI : 10.1109/CVPR.2007.383249
MAP Estimation Via Agreement on Trees: Message-Passing and Linear Programming, IEEE Transactions on Information Theory, vol.51, issue.11, 2005. ,
DOI : 10.1109/TIT.2005.856938
MAP estimation, linear programming and belief propagation with convex free energies, UAI, 2007. ,
A Linear Programming Approach to Max-Sum Problem: A Review, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.7, 2007. ,
DOI : 10.1109/TPAMI.2007.1036
Revisting the linear programming relaxation approach to Gibbs energy minimization and weighted constraint satisfaction, 2010. ,
