New interface
Conference papers
On Output-based Sliding Mode Control Design Using Minimax Observer
Sergiy Zhuk 1 Andrey Polyakov 2
2 NON-A - Non-Asymptotic estimation for online systems
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : The classical problem of the sliding mode control design, which guarantees finite-time reaching and further system motion on a linear hyperplane, is considered for the linear time-invariant disturbed system with the noised measurements of the output. The control law, which provides to the closed-loop system the optimal reaching (as close as possible) of the selected sliding surface, is designed using minimax state observer. The case of discontinuous and continuous admissible feedbacks are studied. The theoretical results are supported by numerical simulations.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01071233
Contributor : Andrey Polyakov Connect in order to contact the contributor
Submitted on : Tuesday, October 7, 2014 - 9:49:26 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Thursday, January 8, 2015 - 10:31:24 AM
File
Zhuk_Polyakov_VSS2014.pdf
Identifiers
  • HAL Id : hal-01071233, version 2
Citation
Sergiy Zhuk, Andrey Polyakov. On Output-based Sliding Mode Control Design Using Minimax Observer. International Workshop on Variable Structure Systems, Jun 2014, Nantes, France. ⟨hal-01071233v2⟩
Share
Metrics
Record views
221
Files downloads
282
