From network-level measurements to expected Quality of Experience: the Skype use case
Salim Afra 1 Damien Saucez 1 Chadi Barakat 1, *
* Corresponding author
1 DIANA - Design, Implementation and Analysis of Networking Architectures
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Applications rely on rich multimedia contents and experience of end users is sensitive to network conditions. Consequently, network operators must design their infrastructure to ensure high Quality of Experience (QoE) for their customers. However, applications are usually over-the-top services on which network operators have no control and users have no mean to tune the network when they undergo poor QoE. In this paper, we propose a method that allows network operators to determine how their network performance will influence QoE and end users to predict the QoE even before launching their applications. We predict the subjective QoE users will undergo based on the knowledge of objective network performance parameters obtained with active measurements (e.g., delay, loss) and machine learning. With the particular case of Skype calls and using a decision tree, we show that our approach achieves 83% of accuracy when estimating QoE from the delay, bandwidth, and loss. Our method can be seen as a new way of performing measurements at the Internet access, where instead of expressing the expected performance in terms of network-level measurements, the performance of the access is expressed in clear terms related to the expected quality for the main applications of interest to the end user. The strength of the approach is in its capacity of expressing directly the QoE as a function of network-level measurements, which is an enabler for QoE prediction, and in reusing the same network-level measurements as input to different models for the QoE of end user applications.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
https://hal.inria.fr/hal-01071373
Contributor : Chadi Barakat <>
Submitted on : Friday, October 3, 2014 - 8:18:55 PM
Last modification on : Saturday, August 29, 2015 - 1:03:28 AM
Long-term archiving on: Friday, April 14, 2017 - 1:55:19 PM
File
main.pdf
Identifiers
  • HAL Id : hal-01071373, version 1
Citation
Salim Afra, Damien Saucez, Chadi Barakat. From network-level measurements to expected Quality of Experience: the Skype use case. 2014. ⟨hal-01071373v1⟩
Share
Metrics
Record views
228
Files downloads
292
