Comments on the hierarchically structured bin packing problem
We study the hierarchically structured bin packing problem. In this problem, the items to be packed into bins are at the leaves of a tree. The objective of the packing is to minimize the total number of bins into which the descendants of an internal node are packed, summed over all internal nodes. We investigate an existing algorithm and make a correction to the analysis of its approximation ratio. Further results regarding the structure of an optimal solution and a strengthened inapproximability result are given.
