Motion planning for non-holonomic mobile robots using the i-PID controller and potential field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper proposes a motion planning approach for non-holonomic mobile robots. Firstly, motion planning using i-PID controller is presented. Then we improve the old potential field function to produce smooth repulsive force. Finally a new repulsive function of robot orientation and angular velocity is proposed to improve the performance of obstacle avoidance. The effectiveness and the robustness of the proposed method are shown thereafter via several simulations.
IROS2014.pdf (415.49 Ko) Télécharger le fichier
hal-01071506 , version 1 (30-10-2014)
  • HAL Id : hal-01071506 , version 1
Yingchong Ma, Gang Zheng, Wilfrid Perruquetti, Zhaopeng Qiu. Motion planning for non-holonomic mobile robots using the i-PID controller and potential field. IEEE/RSJ Conference on Intelligent Robots and Systems (IROS), 2014, Sep 2014, Chicago, United States. ⟨hal-01071506⟩
196 Consultations
524 Téléchargements
