Web Document Summarization by Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper adresses the issue of Web document summarization. We consider the context of a Web document by the set of pieces of information extracted from the content of all the documents linked to it. We put forward two new summarization by context algorithms. The first one uses both the content and the context and the second one relies only on the elements of the context. It is shown that summaries based on the context are usually much more relevant than those only made from the content of the target. Optimal conditions on the size of the content and the context of the document to yield the best summaries are studied.
Fichier non déposé
hal-01072200 , version 1 (07-10-2014)
  • HAL Id : hal-01072200 , version 1
Jean-Yves Delort, Bernadette Bouchon-Meunier, Maria Rifqi. Web Document Summarization by Context. Twelfth International World Wide Web Conference, WWW2003, May 2003, Budapest, Hungary. ⟨hal-01072200⟩
110 Consultations
0 Téléchargements
