Journal articles
Nondiffusive conservative schemes based on approximate Riemann solvers for Lagrangian gas dynamics
Abstract : In this paper, we present a conservative finite volume scheme for the gas dynamics in Lagrangian coordinates, which is fast and nondiffusive. Fast, because it relies on an approximate Riemann solver, and hence the costly resolution of Riemann problems is avoided. Nondiffusive, because the solution is exact when the initial data is an admissible isolated shock, and discontinuities are sharply captured in general. The construction of the scheme uses two main tools: the extension to the barotropic Euler equations of the discontinuous reconstruction strategy presented in [Agu14], and the approximate Riemann solver of [CC13], which is exact on isolated admissible shocks. Numerical experiments in 1D and 2D are proposed.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01073680
Contributor : Nina Aguillon Connect in order to contact the contributor
Submitted on : Friday, October 10, 2014 - 12:05:37 PM
Last modification on : Monday, December 13, 2021 - 9:16:19 AM
Long-term archiving on: : Sunday, January 11, 2015 - 10:46:12 AM
ReconstructionARS.pdf
Identifiers
Citation
Nina Aguillon, Christophe Chalons. Nondiffusive conservative schemes based on approximate Riemann solvers for Lagrangian gas dynamics. ESAIM: Mathematical Modelling and Numerical Analysis, EDP Sciences, 2016, 50 (6), pp.1887 - 1916. ⟨10.1051/m2an/2016010⟩. ⟨hal-01073680⟩
Share
Metrics
Record views
186
Files downloads
172
