Locally Weighted Regression: An Approach to Regression Analysis by Local Fitting, Journal of the American Statistical Association, vol.41, issue.810345, p.596610, 1988. ,
DOI : 10.1080/01621459.1988.10478639
Locally Weighted Learning, Artificial Intelligence Review, vol.11, issue.1, pp.11-7310, 1997. ,
DOI : 10.1007/978-94-017-2053-3_2
Non-linear regression algorithms for motor skill acquisition: a comparison, p.14, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01090848
A generalized inverse for matrices, Mathematical Proceedings of the Cambridge Philosophical Society, vol.11, issue.03, pp.406-413, 1955. ,
DOI : 10.1093/qmath/2.1.189
A Limited Memory Algorithm for Bound Constrained Optimization, SIAM Journal on Scientific Computing, vol.16, issue.5, pp.1190-1208, 1995. ,
DOI : 10.1137/0916069
Algorithm 778: L-BFGS-B: Fortran subroutines for large-scale bound-constrained optimization, ACM Transactions on Mathematical Software, vol.23, issue.4, pp.550-560, 1997. ,
DOI : 10.1145/279232.279236
Active learning of inverse models with intrinsically motivated goal exploration in robots, Robotics and Autonomous Systems, vol.61, issue.1, p.2012 ,
DOI : 10.1016/j.robot.2012.05.008
URL : https://hal.archives-ouvertes.fr/hal-00788440
Goal Babbling for an Efficient Bootstrapping of Inverse Models in High Dimensions, p.2012 ,
Exploration in model-based reinforcement learning by empirically estimating learning progress, Neural Information Processing System (NIPS), p.2012 ,
URL : https://hal.archives-ouvertes.fr/hal-00755248
Autonomous reuse of motor exploration trajectories, 2013 IEEE Third Joint International Conference on Development and Learning and Epigenetic Robotics (ICDL) ,
DOI : 10.1109/DevLrn.2013.6652567
URL : https://hal.archives-ouvertes.fr/hal-00850759
Probabilistic policy reuse in a reinforcement learning agent, Proceedings of the fifth international joint conference on Autonomous agents and multiagent systems , AAMAS '06, pp.720-727, 2006. ,
DOI : 10.1145/1160633.1160762
Transferring Instances for Model-Based Reinforcement Learning, Machine Learning and Knowledge Discovery in Databases, pp.488-505, 2008. ,
DOI : 10.1007/978-3-540-87481-2_32
Transfer learning for reinforcement learning domains: A survey, The Journal of Machine Learning Research, vol.10, pp.1633-1685, 2009. ,
A Survey on Transfer Learning, IEEE Transactions on Knowledge and Data Engineering, vol.22, issue.10, pp.1345-1359 ,
DOI : 10.1109/TKDE.2009.191
Transfer Learning, Handbook of Research on Machine Learning Applications, 2009. ,
DOI : 10.4018/978-1-60566-766-9.ch011
Transfer Learning by Discovering Latent Task Parametrizations, the NIPS 2012 Workshop on Bayesian Nonparametric Models for Reliable Planning And Decision-Making Under Uncertainty, 2012. ,
Transfer of Experience Between Reinforcement Learning Environments with Progressive Difficulty, Artificial Intelligence Review, vol.21, issue.3/4, pp.3-4, 2004. ,
DOI : 10.1023/B:AIRE.0000036264.95672.64
Transfer learning for reinforcement learning on a physical robot, The Ninth International Conference on Autonomous Agents and Multiagent Systems - Adaptive Learning Agents Workshop, 2010. ,
Lifelong robot learning, Robotics and Autonomous Systems, vol.15, issue.1-2, 1995. ,
DOI : 10.1016/0921-8890(95)00004-Y
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.18.1803
Lifelong Machine Learning Systems: Beyond Learning Algorithms, 2013 AAAI Spring Symposium Series, 2013. ,
On the notion of motor primitives in humans and robots, 2005. ,
Movement imitation with nonlinear dynamical systems in humanoid robots, Proceedings 2002 IEEE International Conference on Robotics and Automation (Cat. No.02CH37292), p.13981403, 2002. ,
DOI : 10.1109/ROBOT.2002.1014739
Dynamical Movement Primitives: Learning Attractor Models for Motor Behaviors, Neural Computation, vol.2010, issue.11, p.328373, 2012. ,
DOI : 10.1109/AT-EQUAL.2009.32
Joining Movement Sequences: Modified Dynamic Movement Primitives for Robotics Applications Exemplified on Handwriting, IEEE Transactions on Robotics, vol.28, issue.1, pp.145-157, 2012. ,
DOI : 10.1109/TRO.2011.2163863
DmpBbo ? A C++ library for black-box optimization of dynamical movement primitives, p.2014 ,
