New interface
Conference papers
A Penetration-free Nonsmooth Dynamics Method for Frictionless Contact/Impact Problems
Abstract : This paper studies numerical algorithms for the simulation of mechanical systems including rigid and flexible bodies, kinematic joints and frictionless contact conditions. The condition of impenetrability of the bodies in contact is expressed as a unilateral constraint, with the consequence that impacts and/or instantaneous changes in the velocities may arise in the dynamic response. When dynamic contacts are analyzed between elastic solids and structures, the gap velocity is necessarily discontinuous otherwise a non-physical penetration of the bodies would occur. When contacts between rigid bodies are studied, e.g., in multibody systems, impulsive reaction forces can also occur leading to an instantaneous change in the linear and angular momenta of each body. Standard schemes, such as the Newmark, HHT or generalized-α methods, are not consistent in these cases since the numerical response may artificially generate energy when a contact occurs. In order to analyze impact phenomena, nonsmooth time integration methods have been proposed in the literature and can be classified into two main groups, namely, event-driven schemes and time-stepping schemes. Event-driven schemes are accurate for the free flight smooth motions and are especially suitable for small multi-body systems with a limited number of events, but they become inefficient if frequent transitions occur in a short time. Time-stepping methods, such as Moreau–Jean scheme, have been proven to be convergent and robust even for a large number of events, and are extensively applied as the solution to nonsmooth system models.
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/hal-01075153
Contributor : Vincent Acary Connect in order to contact the contributor
Submitted on : Thursday, October 16, 2014 - 5:54:55 PM
Last modification on : Thursday, November 10, 2022 - 4:22:13 AM
Long-term archiving on: : Saturday, January 17, 2015 - 10:56:32 AM
File
a2537.pdf
Identifiers
  • HAL Id : hal-01075153, version 1
Citation
Olivier Brüls, Vincent Acary, Alberto Cardona. A Penetration-free Nonsmooth Dynamics Method for Frictionless Contact/Impact Problems. WCCM XI - 11th World Congress on Computational Mechanics - 5th European Conference on Computational Mechanics (ECCM V) 6th European Conference on Computational Fluid Dynamics (ECFD VI), Eugenio Oñate, Jul 2014, Barcelona, Spain. ⟨hal-01075153⟩
Share
Metrics
Record views
371
Files downloads
96
