C++ template metaprogramming: concepts, tools, and techniques from Boost and beyond, 2004. ,
StarPU: a unified platform for task scheduling on heterogeneous multicore architectures. Concurrency and Computation: Practice and Experience, pp.187-198, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
Fast and reliable solutions for numerical linear algebra solvers in highperformance computing, 2012. ,
URL : https://hal.archives-ouvertes.fr/tel-00967523
A Parallel Tiled Solver for Dense Symmetric Indefinite Systems on Multicore Architectures, 2012 IEEE 26th International Parallel and Distributed Processing Symposium, pp.14-24, 2012. ,
DOI : 10.1109/IPDPS.2012.12
URL : https://hal.archives-ouvertes.fr/inria-00631361
Accelerating scientific computations with mixed precision algorithms, Computer Physics Communications, vol.180, issue.12, pp.2526-2533, 2009. ,
DOI : 10.1016/j.cpc.2008.11.005
URL : http://arxiv.org/abs/0808.2794
A Class of Communication-avoiding Algorithms for Solving General Dense Linear Systems on CPU/GPU Parallel Machines, International Conference on Computational Science of Procedia Computer Science, pp.17-26, 2012. ,
DOI : 10.1016/j.procs.2012.04.003
URL : https://hal.archives-ouvertes.fr/hal-00656457
Computing the conditioning of the components of a linear least-squares solution. Numerical Linear Algebra with Applications, pp.517-533, 2009. ,
Accelerating Linear System Solutions Using Randomization Techniques, ACM Transactions on Mathematical Software, vol.39, issue.2, p.2013 ,
DOI : 10.1145/2427023.2427025
URL : https://hal.archives-ouvertes.fr/inria-00593306
Cusp: Generic parallel algorithms for sparse matrix and graph computations ,
THRUST: a productivity-oriented library for CUDA, GPU Computing Gems, vol.7, 2011. ,
DOI : 10.1016/B978-0-12-811986-0.00033-9
Stability analysis of the method of semi-normal equations for least squares problems. Linear Algebra and its Applications, pp.31-48, 1987. ,
Numerical methods for least squares problems. Siam, 1996. ,
D language Templates revisited ,
Algorithmic Skeletons, 1989. ,
DOI : 10.1007/978-1-4471-0841-2_13
Armadillo: An open source C++ linear algebra library for fast prototyping and computationally intensive experiments, 2010. ,
Generative Programming and Active Libraries, Generic Programming, pp.25-39, 2000. ,
DOI : 10.1007/3-540-39953-4_3
Components and Generative Programming, Software Engineering?ESEC/FSE'99, pp.2-19, 1999. ,
DOI : 10.1007/3-540-48166-4_2
Generative Programming, 2000. ,
DOI : 10.1007/3-540-36208-8_2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.387.6297
Generative Programming, Object-Oriented Technology ECOOP 2002 Workshop Reader, pp.15-29, 2002. ,
VexCL: Vector expression template library for OpenCL, 2012. ,
Error bounds from extra-precise iterative refinement, ACM Transactions on Mathematical Software, vol.32, issue.2, pp.325-351, 2006. ,
DOI : 10.1145/1141885.1141894
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.4101
Basic Linear Algebra Subprograms Technical Forum Standard, Int. J. of High Performance Computing Applications, vol.16, issue.1, 2002. ,
DOI : 10.1177/10943420020160010101
SkePU, Proceedings of the fourth international workshop on High-level parallel programming and applications, HLPP '10, pp.5-14, 2010. ,
DOI : 10.1145/1863482.1863487
The numerical template toolbox: A modern C++ design for scientific computing, Journal of Parallel and Distributed Computing, vol.74, issue.12, 2014. ,
DOI : 10.1016/j.jpdc.2014.07.002
URL : https://hal.archives-ouvertes.fr/hal-01061305
Meta-programming Applied to Automatic SMP Parallelization of Linear Algebra Code, Euro-Par 2008?Parallel Processing, pp.729-738, 2008. ,
DOI : 10.1007/978-3-540-85451-7_78
Representation-transparent matrix algorithms with scalable performance, Proceedings of the 21st annual international conference on Supercomputing, ICS '07, pp.116-125, 2007. ,
DOI : 10.1145/1274971.1274989
An Introduction to GCC, Network Theory Ltd, 2004. ,
Concepts, ACM SIGPLAN Notices, vol.41, issue.10, pp.291-310, 2006. ,
DOI : 10.1145/1167515.1167499
Eigen v3, 2010. ,
Accuracy and Stability of Numerical Algorithms, SIAM, 2002. ,
DOI : 10.1137/1.9780898718027
Expression Templates Revisited: A Performance Analysis of Current Methodologies, SIAM Journal on Scientific Computing, vol.34, issue.2, pp.42-69, 2012. ,
DOI : 10.1137/110830125
Math Kernel Library (MKL) http://www.intel.com/software/products ,
Looking back at dense linear algebra software, Journal of Parallel and Distributed Computing, vol.74, issue.7, 2013. ,
DOI : 10.1016/j.jpdc.2013.10.005
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.260.120
STL tutorial and reference guide: C++ programming with the standard template library, 2009. ,
LSQR: An Algorithm for Sparse Linear Equations and Sparse Least Squares, ACM Transactions on Mathematical Software, vol.8, issue.1, pp.43-71, 1982. ,
DOI : 10.1145/355984.355989
Guest Editor's Introduction: Model-Driven Engineering, Computer, vol.39, issue.2, pp.25-31, 2006. ,
DOI : 10.1109/MC.2006.58
Template meta-programming for Haskell, ACM SIGPLAN Notices, vol.37, issue.12, pp.60-75, 2002. ,
DOI : 10.1145/636517.636528
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.189.4479
A Gentle Introduction to Multi-stage Programming, Domain-Specific Program Generation, pp.30-50, 2004. ,
DOI : 10.1007/978-3-540-25935-0_3
Towards dense linear algebra for hybrid GPU accelerated manycore systems, Code Generation and Optimization, 2003. CGO 2003. International Symposium on, pp.232-240, 2003. ,
DOI : 10.1016/j.parco.2009.12.005
The libflame library for dense matrix computations, Computing in science & engineering, vol.11, issue.6, pp.56-63, 2009. ,
Active libraries: Rethinking the roles of compilers and libraries, Proceedings of the SIAM Workshop on Object Oriented Methods for Interoperable Scientific and Engineering Computing (OO'98, 1998. ,
Expression templates, C++ Report, vol.7, pp.26-31, 1995. ,
The boost uBLAS library, 2002. ,
Automatically Tuned Linear Algebra Software, Proceedings of the IEEE/ACM SC98 Conference, pp.1-27, 1998. ,
DOI : 10.1109/SC.1998.10004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.3487
