Journal articles
On noise reduction in strain maps obtained with the grid method by averaging images affected by vibrations
Frédéric Sur 1 Michel Grediac 2
1 MAGRIT - Visual Augmentation of Complex Environments
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : Any image-based contactless measurement system has a limited resolution because of sensor noise. If the sensor is rigorously static with respect to the imaged object, a possibility is to reduce noise by averaging images acquired at different times. This paper discusses images of a pseudo-periodic grid used in experimental solid mechanics to give estimations of in-plane displacement and strain components of a deformed flat specimen. Because of the magnification factor which is employed, the grid images are often affected by residual vibrations, thereby invalidating the assumption that the sensor is static. The averaged grid image is thus a biased estimator of the unknown noise-free image. In spite of this, we prove that the retrieved displacement and strain components still benefit from noise reduction by time-averaging. A theoretical model is discussed, and experiments on real and synthetic data sets are provided.
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01075764
Contributor : Frédéric Sur Connect in order to contact the contributor
Submitted on : Monday, October 20, 2014 - 10:43:12 AM
Last modification on : Saturday, June 25, 2022 - 7:40:51 PM
Long-term archiving on: : Wednesday, January 21, 2015 - 10:35:28 AM
File
grid_denoising_Sur_Grediac.pdf
Identifiers
Citation
Frédéric Sur, Michel Grediac. On noise reduction in strain maps obtained with the grid method by averaging images affected by vibrations. Optics and Lasers in Engineering, Elsevier, 2015, 66, pp.210-222. ⟨10.1016/j.optlaseng.2014.09.013⟩. ⟨hal-01075764⟩
Share
Metrics
Record views
419
Files downloads
164
