Theory of Elasticity for Scientists and Engineers, 2000. ,
DOI : 10.1007/978-1-4612-1330-7
Demodulation of spatial carrier images: performance analysis of several algorithms using a single image, Experimental Mechanics, issue.8, pp.531357-1370, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00834981
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.95102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
Strain Measurement by Digital Image Correlation: Influence of Two Types of Speckle Patterns Made from Rigid or Deformable Marks, Strain, vol.36, issue.5, pp.357-365, 2012. ,
DOI : 10.1111/j.1475-1305.2011.00831.x
Assessment of Digital Image Correlation Measurement Errors: Methodology and Results, Experimental Mechanics, vol.43, issue.4, pp.49353-370, 2009. ,
DOI : 10.1007/s11340-008-9204-7
URL : https://hal.archives-ouvertes.fr/hal-00881043
Patch-Based Nonlocal Functional for Denoising Fluorescence Microscopy Image Sequences, IEEE Transactions on Medical Imaging, vol.29, issue.2, pp.442-454, 2010. ,
DOI : 10.1109/TMI.2009.2033991
URL : https://hal.archives-ouvertes.fr/inria-00541082
CCD noise removal in digital images, IEEE Transactions on Image Processing, vol.15, issue.9, pp.2676-2685, 2006. ,
DOI : 10.1109/TIP.2006.877363
Practical Poissonian-Gaussian Noise Modeling and Fitting for Single-Image Raw-Data, IEEE Transactions on Image Processing, vol.17, issue.10, pp.1737-1754, 2008. ,
DOI : 10.1109/TIP.2008.2001399
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, pp.716-734, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.009
Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Two-dimensional windowed Fourier transform for fringe pattern analysis: Principles, applications and implementations, Optics and Lasers in Engineering, vol.45, issue.2, pp.304-317, 2007. ,
DOI : 10.1016/j.optlaseng.2005.10.012
Error estimation in measuring strain fields with DIC on planar sheet metal specimens with a non-perpendicular camera alignment, Optics and Lasers in Engineering, vol.49, issue.1, pp.57-65, 2011. ,
DOI : 10.1016/j.optlaseng.2010.08.017
Secrets of image denoising cuisine, Acta Numerica, vol.21, issue.1, pp.475-576, 2012. ,
DOI : 10.1017/S0962492912000062
A Tour of Modern Image Filtering: New Insights and Methods, Both Practical and Theoretical, IEEE Signal Processing Magazine, vol.30, issue.1, pp.106-128, 2013. ,
DOI : 10.1109/MSP.2011.2179329
Image restoration with noise suppression using a multiresolution support, Astronomy and astrophysics, vol.112, pp.179-189, 1995. ,
A note on the Delta method. The American Statistician, pp.27-29, 1992. ,
Enhancing with deconvolution the metrological performance of the grid method for in-plane strain measurement, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.1563-1567, 2013. ,
DOI : 10.1109/ICASSP.2013.6637914
URL : https://hal.archives-ouvertes.fr/hal-00804719
Measuring the Noise of Digital Imaging Sensors by Stacking Raw Images Affected by Vibrations and Illumination Flickering, SIAM Journal on Imaging Sciences, vol.8, issue.1, 2014. ,
DOI : 10.1137/140977035
URL : https://hal.archives-ouvertes.fr/hal-01133358
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Additive noise effect in digital phase detection, Applied Optics, vol.36, issue.1, pp.271-276, 1997. ,
DOI : 10.1364/AO.36.000271
Photomechanics, volume 77 of Topics in Applied Physics, chapter Fringe analysis, pp.55-102, 2000. ,
Image Correlation for Shape, Motion and Deformation Measurements, 2009. ,
Thermal detectivity enhancement of visible and near infrared thermography by using super-resolution algorithm: Possibility to generalize the method to other domains, Journal of Applied Physics, vol.105, issue.6, pp.64911-064914, 2009. ,
DOI : 10.1063/1.3086636
URL : https://hal.archives-ouvertes.fr/hal-00364281
Theory of elasticity, 1970. ,
Precision verification of a simplified three-dimensional DIC method, Optics and Lasers in Engineering, vol.49, issue.7, pp.937-945, 2011. ,
DOI : 10.1016/j.optlaseng.2011.02.006
