Journal articles
Structure of the Al2Cu(001) and Al9Co2(001) surfaces: role of the covalent-like bonding network and off-stoichiometric effects
Abstract : The Al2Cu and Al9Co2 intermetallic compounds share structural similarities: they are bothdescribed in terms of coordination polyedra with a tetragonal symmetry and covalent-like bonding occur in both compounds. In this paper, the (001) surface structure of Al2Cu and Al9Co2 is described based on a combined scanning tunneling microscopy (STM), low-energy electron diffraction (LEED), X-ray and ultraviolet photoemission spectroscopy (XPS and UPS) and density functional theory (DFT) study. Surface models are elaborated from stoichiometric ideal compounds, leading to a pure aluminium plane as the surface termination in both cases. The nature of the constitutional defect in Al9Co2 is determined using density functional theory calculations. The influence of the surface atomic density, of the surface composition and of off-stoichiometric effects on the (001) surface structures of Al2Cu and Al9Co2 are discussed.
Complete list of metadata
https://hal.inria.fr/hal-01075766
Contributor : Emilie Gaudry Connect in order to contact the contributor
Submitted on : Monday, October 20, 2014 - 10:45:52 AM
Last modification on : Monday, December 13, 2021 - 1:52:02 PM
Identifiers
Collections
Citation
Émilie Gaudry, Sebastián Alarcón Villaseca, Julian Ledieu, Jean-Marie Dubois, Vincent Fournée. Structure of the Al2Cu(001) and Al9Co2(001) surfaces: role of the covalent-like bonding network and off-stoichiometric effects. MRS Proceedings, 2013, 1517, 9 p. ⟨10.1557/opl.2012.1570⟩. ⟨hal-01075766⟩
Share
Metrics
Record views
120
