Directions of work or proceedings
A modeling and code generation framework for critical embedded systems design: From Simulink down to VHDL and Ada/C code
Abstract : The P project gathers industrial and academic partners to address the issue of a modeling approach and automatic code generation for critical embedded systems. Works target the definition of an open design flow which integrates qualified tools to produce both hardware and software implementations. This paper introduces the project through two code generators that allow generating Ada, C and VHDL from Simulink. Application of the design flow to two industrial case studies is finally presented.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01075807
Contributor : Cyrille Chavet Connect in order to contact the contributor
Submitted on : Monday, October 20, 2014 - 12:17:09 PM
Last modification on : Monday, March 14, 2022 - 11:08:08 AM
Identifiers
  • HAL Id : hal-01075807, version 1
Citation
Bordin Matteo, Mickael Lanoe, Dominique Heller, Cyrille Chavet, Philippe Coussy. A modeling and code generation framework for critical embedded systems design: From Simulink down to VHDL and Ada/C code. 21st IEEE International Conference on Electronics Circuits & Systems, Dec 2014, Marseille, France. 2014. ⟨hal-01075807⟩
Share
Metrics
Record views
136
