Surface structures of In-Pd intermetallic compounds. II. A theoretical study
Abstract : The (110) surface of the InPd intermetallic compound and the In–Pd surface alloy properties are investigated in the framework of the density functional theory, within the projector augmented plane-wave method. Surface segregation is calculated to be energetically unfavorable at stoichiometric InPd(110) surfaces, while indium antisites are shown to segregate to the surface in off-stoichiometric InPd(110) systems. Concerning surface alloys obtained by burying In-doped Pd layers in Pd(111), we demonstrated that the most stable ones are those presenting atomic indium concentrations below 50 at. % (11 at. %, 25 at. %, 33 at. %). According to our calculations, the In-doped Pd layers with concentration above or equal to 50% lead to In-doped Pd multilayers, each presenting an atomic indium concentration below 50 at. %. Alloying and segregation effects in InPd intermetallic compound and In–Pd surface alloys clearly agree with the larger bonding strength of In–Pd (−0.44 eV) compared to In–In (−0.29 eV) and Pd–Pd (−0.31 eV).
Type de document :
Article dans une revue
Journal of Chemical Physics, 2014, 141, 084703 (9 p.). 〈10.1063/1.4892409〉
Liste complète des métadonnées
Littérature citée [53 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01075951
Contributeur : Emilie Gaudry <>
Soumis le : lundi 3 novembre 2014 - 13:27:42
Dernière modification le : lundi 9 avril 2018 - 12:40:06
Document(s) archivé(s) le : mercredi 4 février 2015 - 10:06:08
Fichier
1.4892409n (1).pdf
Fichiers éditeurs autorisés sur une archive ouverte
Collections
Citation
É. Gaudry, G. M. Mcguirk, J. Ledieu, V. Fournée. Surface structures of In-Pd intermetallic compounds. II. A theoretical study. Journal of Chemical Physics, 2014, 141, 084703 (9 p.). 〈10.1063/1.4892409〉. 〈hal-01075951〉
Métriques
Consultations de la notice
135
Téléchargements de fichiers
412
