Optimal Base Station Placement: A Stochastic Method Using Interference Gradient In Downlink Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we study the optimal placement and optimal number of base stations added to an existing wireless data network through the interference gradient method. This proposed method considers a sub-region of the existing wireless data network, hereafter called region of interest. In this region, the provider wants to increase the network coverage and the users throughput. In this aim, the provider needs to determine the optimal number of base stations to be added and their optimal placement. The proposed approach is based on the Delaunay triangulation of the region of interest and the gradient descent method in each triangle to compute the minimum interference locations. We quantify the increase of coverage and throughput.
valuetools2011.pdf (1.08 Mo) Télécharger le fichier
hal-01076514 , version 1 (22-10-2014)
Copyright (Tous droits réservés)
Salman Malik, Alonso Silva, Jean-Marc Kelif. Optimal Base Station Placement: A Stochastic Method Using Interference Gradient In Downlink Case. International Conference on Performance Evaluation Methodologies and Tools (ValueTools), May 2011, Cachan, France. ⟨10.4108/icst.valuetools.2011.245736⟩. ⟨hal-01076514⟩
47 Consultations
72 Téléchargements
