A theoretical foundation for language aggregation
Programming languages should be formally specified in order to reason about programs written in them. We show that, given two formally specified programming languages, it is possible to construct the formal semantics of an aggregated language, in which programs consist of pairs of programs from the initial languages. The construction is based on algebraic techniques and it can be used to reduce relational properties (such as equivalence of programs) to reachability properties (in the aggregated language).
Informatique [cs]
