Improving Semantic Transparency of Committee-Designed Languages through Crowd-sourcing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Committee-designed languages such as those of the OMG consor-tium are widely used in both industry and academia. These lan-guages seem to be used increasingly by users with no technical background for the visualization, documentation and specification of workflows, data and software systems. However, according to several studies on these languages, the used visual notations do not seem to convey any particular semantics and the recognition of such notations is not perceptually immediate. This lack of se-mantic transparency increases the cognitive load to differentiate concepts from each other and slows down recognition and learning of the language constructs. This paper proposes a process, which leverages the crowd-sourcing to improve the semantic transparency of such languages. We believe that involving end-users in the de-sign process of the languages visual notations should increase the expressiveness of these languages and then their acceptance for a wide range of novice-users.
DSM.pdf (354.18 Ko) Télécharger le fichier
hal-01076729 , version 1 (22-10-2014)
  • HAL Id : hal-01076729 , version 1
Amine El Kouhen, Abdelouahed Gherbi, Cédric Dumoulin. Improving Semantic Transparency of Committee-Designed Languages through Crowd-sourcing. 14th Workshop on Domain-Specific Modeling @ SPLASH, Oct 2014, Oregon - Portland, United States. ⟨hal-01076729⟩
148 Consultations
87 Téléchargements
