Convergence of finite volumes schemes for the coupling between the inviscid Burgers equation and a particle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2017
In this paper, we prove the convergence of a class of finite volume schemes for the model of coupling between a Burgers fluid and a pointwise particle introduced in [LST08]. In this model, the particle is seen as a moving interface through which an interface condition is imposed, which links the velocity of the fluid on the left and on the right of the particle and the velocity of the particle (the three quantities are all not equal in general). The total impulsion of the system is conserved through time.The proposed schemes are consistent with a “large enough” part of the interface conditions. The proof of convergence is an extension of the one of [AS12] to the case where the particle moves under the influence of the fluid. It yields two main difficulties: first, we have to deal with time-dependent flux and interface condition, and second with the coupling between and ODE and a PDE.
ConvergenceBurgersParticle.pdf (383.61 Ko) Télécharger le fichier
hal-01077311 , version 1 (24-10-2014)
Nina Aguillon, Frédéric Lagoutière, Nicolas Seguin. Convergence of finite volumes schemes for the coupling between the inviscid Burgers equation and a particle. Mathematics of Computation, 2017, 86, pp.157-196 ⟨10.1090/mcom/3082⟩. ⟨hal-01077311⟩
343 Consultations
141 Téléchargements
