PARADE: A Massively Parallel Differential Evolution Template for EASEA, Swarm and Evolutionary Computation, pp.12-20 ,
DOI : 10.1007/978-3-642-29353-5_2
Jump-Diffusion Calibration Using Differential Evolution, Wilmott, vol.2011, issue.55, pp.76-79, 2011. ,
DOI : 10.1002/wilm.10034
Differential Evolution with DEoptim: An application to non-convex portfolio optimization, The R Journal, vol.3, issue.1, pp.27-34, 2011. ,
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Algorithms (X, sigma, eta): Quasi-random Mutations for Evolution Strategies, p.12, 2005. ,
DOI : 10.1007/11740698_26
URL : https://hal.archives-ouvertes.fr/inria-00000544
The Theory of Evolution Strategies. Natural Computing Series, 2001. ,
Defining a Standard for Particle Swarm Optimization, 2007 IEEE Swarm Intelligence Symposium, pp.120-127, 2007. ,
DOI : 10.1109/SIS.2007.368035
Self-Adapting Control Parameters in Differential Evolution: A Comparative Study on Numerical Benchmark Problems, IEEE Transactions on Evolutionary Computation, vol.10, issue.6, pp.646-657, 2006. ,
DOI : 10.1109/TEVC.2006.872133
A parallel particle swarm optimization algorithm with communication strategies, J. Inf. Sci. Eng, vol.21, issue.4, pp.809-818, 2005. ,
Beyond standard particle swarm optimisation, IJSIR, vol.1, issue.4, pp.46-61, 2010. ,
The particle swarm - explosion, stability, and convergence in a multidimensional complex space, IEEE Transactions on Evolutionary Computation, vol.6, issue.1, pp.58-73, 2002. ,
DOI : 10.1109/4235.985692
A probabilistic Theory of Pattern Recognition, 1997. ,
DOI : 10.1007/978-1-4612-0711-5
Lower Bounds for Comparison Based Evolution Strategies Using VC-dimension and Sign Patterns, Algorithmica, vol.XVI, issue.2, 2010. ,
DOI : 10.1007/s00453-010-9391-3
URL : https://hal.archives-ouvertes.fr/inria-00452791
A speculative approach to parallelization in particle swarm optimization, Swarm Intelligence, vol.1, issue.1, pp.77-116, 2012. ,
DOI : 10.1007/s11721-011-0066-8
An Adaptive Differential Evolution Algorithm With Novel Mutation and Crossover Strategies for Global Numerical Optimization, IEEE Transactions on Systems, Man, and Cybernetics, Part B (Cybernetics), vol.42, issue.2, pp.482-500, 2012. ,
DOI : 10.1109/TSMCB.2011.2167966
Particle swarm optimization, Proceedings of ICNN'95, International Conference on Neural Networks, pp.1942-1948, 1995. ,
DOI : 10.1109/ICNN.1995.488968
A Fuzzy Adaptive Differential Evolution Algorithm, Soft Computing, vol.9, issue.6, pp.448-462, 2005. ,
DOI : 10.1007/s00500-004-0363-x
Fuzzy Controlled Parallel PSO to Solving Large Practical Economic Dispatch, IEEE Proceedings of the 2010 IEEE International Conference of the IEEE Industrial Electronics Society, pp.2695-2701, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00564733
Differential evolution algorithm with ensemble of parameters and mutation strategies, <ce:title>The Impact of Soft Computing for the Progress of Artificial Intelligence</ce:title>, pp.1679-1696, 2011. ,
DOI : 10.1016/j.asoc.2010.04.024
Parallel PSO using MapReduce, 2007 IEEE Congress on Evolutionary Computation, pp.7-14, 2007. ,
DOI : 10.1109/CEC.2007.4424448
A new asynchronous parallel global optimization method based on simulated annealing and differential evolution, Applied Soft Computing, vol.11, issue.1, pp.1481-1489, 2011. ,
DOI : 10.1016/j.asoc.2010.04.019
Parameter selection and adaptation in Unified Particle Swarm Optimization, Mathematical and Computer Modelling, vol.46, issue.1-2, pp.198-213, 2007. ,
DOI : 10.1016/j.mcm.2006.12.019
Tuning & simplifying heuristical optimization, 2010. ,
Jade, an adaptive differential evolution algorithm, benchmarked on the bbob noiseless testbed, Proceedings of the fourteenth international conference on Genetic and evolutionary computation conference companion, GECCO Companion '12, pp.197-204 ,
Differential Evolution -A Practical Approach to Global Optimization. Natural Computing, 2006. ,
An improved CUDA-based implementation of differential evolution on GPU, Proceedings of the fourteenth international conference on Genetic and evolutionary computation conference, GECCO '12, pp.991-998, 2012. ,
DOI : 10.1145/2330163.2330301
URL : https://hal.archives-ouvertes.fr/hal-00780081
Evolutionstrategie: Optimierung Technischer Systeme nach Prinzipien des Biologischen Evolution, 1973. ,
Zaslavsky's theorem. Univ. Rice website, 2002. ,
Parallel global optimization with the particle swarm algorithm, International Journal for Numerical Methods in Engineering, vol.28, issue.13, pp.2296-2315, 2003. ,
DOI : 10.1002/nme.1149
A modified particle swarm optimizer, 1998 IEEE International Conference on Evolutionary Computation Proceedings. IEEE World Congress on Computational Intelligence (Cat. No.98TH8360), pp.69-73, 1998. ,
DOI : 10.1109/ICEC.1998.699146
Differential evolution: A simple and efficient heuristic for global optimization over continuous spaces, Journal of Global Optimization, vol.11, issue.4, pp.341-359, 1997. ,
DOI : 10.1023/A:1008202821328
Log(lambda) Modifications for Optimal Parallelism, Parallel Problem Solving From Nature, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00495087
General Lower Bounds for Evolutionary Algorithms, 10 th International Conference on Parallel Problem Solving from Nature, 2006. ,
DOI : 10.1007/11844297_3
URL : https://hal.archives-ouvertes.fr/inria-00112820
The particle swarm optimization algorithm: convergence analysis and parameter selection, Information Processing Letters, vol.85, issue.6, pp.317-325, 2003. ,
DOI : 10.1016/S0020-0190(02)00447-7
URL : https://hal.archives-ouvertes.fr/hal-01313364
The Nature of Statistical Learning, 1995. ,
Parallel Random Injection Differential Evolution, Applications of Evolutionary Computation, pp.471-480, 2010. ,
DOI : 10.1007/978-3-642-12239-2_49
Self-adapting Differential Evolution Algorithm with Chaos Random for Global Numerical Optimization, Advances in Computation and Intelligence, pp.112-122, 2010. ,
DOI : 10.1007/978-3-642-16493-4_12
Multi-population differential evolution with adaptive parameter control for global optimization, Proceedings of the 13th annual conference on Genetic and evolutionary computation, GECCO '11, pp.1093-1098, 2011. ,
DOI : 10.1145/2001576.2001724
Standard Particle Swarm Optimisation 2011 at CEC-2013: A baseline for future PSO improvements, 2013 IEEE Congress on Evolutionary Computation, pp.2337-2344, 2013. ,
DOI : 10.1109/CEC.2013.6557848
JADE: Adaptive Differential Evolution With Optional External Archive, IEEE Transactions on Evolutionary Computation, vol.13, issue.5, pp.945-958, 2009. ,
DOI : 10.1109/TEVC.2009.2014613
