New Route Relaxation and Pricing Strategies for the Vehicle Routing Problem, Operations Research, vol.59, issue.5, pp.1269-1283, 2011. ,
DOI : 10.1287/opre.1110.0975
The volume algorithm: producing primal solutions with a subgradient method, Mathematical Programming, vol.87, issue.3, pp.385-399, 2000. ,
DOI : 10.1007/s101070050002
OR-Library: Distributing Test Problems by Electronic Mail, Journal of the Operational Research Society, vol.41, issue.11, pp.1069-1072, 1990. ,
DOI : 10.1057/jors.1990.166
Acceleration of cutting-plane and column generation algorithms: Applications to network design, Networks, vol.3, issue.5, pp.3-17, 2007. ,
DOI : 10.1002/net.20137
Comparison of bundle and classical column generation, Mathematical Programming, pp.299-344, 2008. ,
DOI : 10.1007/s10107-006-0079-z
URL : https://hal.archives-ouvertes.fr/inria-00070554
On improving relaxation methods by modified gradient techniques, pp.26-34, 1975. ,
DOI : 10.1007/BFb0120697
Grammar-Based Column Generation for Personalized Multi-Activity Shift Scheduling, INFORMS Journal on Computing, vol.25, issue.3, pp.461-474, 2013. ,
DOI : 10.1287/ijoc.1120.0514
Level bundle methods for oracles with on-demand accuracy, Optimization Methods and Software, vol.152, issue.2, pp.1180-1209, 2014. ,
DOI : 10.1007/s12532-012-0038-z
A Cost-Regular Based Hybrid Column Generation Approach, Constraints, vol.12, issue.4???5, pp.315-333, 2006. ,
DOI : 10.1007/s10601-006-9003-7
URL : https://hal.archives-ouvertes.fr/hal-00293562
Stabilized column generation, Discrete Mathematics, vol.194, issue.1-3, pp.229-237, 1999. ,
DOI : 10.1016/S0012-365X(98)00213-1
An Improved Primal Simplex Algorithm for Degenerate Linear Programs, INFORMS Journal on Computing, vol.23, issue.4, pp.569-577, 2011. ,
DOI : 10.1287/ijoc.1100.0425
An In-Out Approach to Disjunctive Optimization, Integration of AI and OR Techniques in Constraint Programming for Combinatorial Optimization Problems, pp.136-140, 2010. ,
DOI : 10.1007/978-3-642-13520-0_17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.566.1064
Bundle methods for sum-functions with ???easy??? components: applications to multicommodity network design, Mathematical Programming, vol.2, issue.1, pp.133-161, 2014. ,
DOI : 10.1007/s10107-013-0642-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.295.7883
Convex nondifferentiable optimization: A survey focused on the analytic center cutting plane method. Optimization Methods and Software, pp.805-867, 2002. ,
New developments in the primal???dual column generation technique, European Journal of Operational Research, vol.224, issue.1, pp.41-51, 2013. ,
DOI : 10.1016/j.ejor.2012.07.024
On the choice of explicit stabilizing terms in column generation, Discrete Applied Mathematics, vol.157, issue.6, pp.1167-1184, 2009. ,
Chebyshev center based column generation, Discrete Applied Mathematics, vol.159, issue.18, pp.2251-2265, 2011. ,
DOI : 10.1016/j.dam.2011.08.009
URL : http://doi.org/10.1016/j.dam.2011.08.009
New variants of bundle methods, Mathematical Programming, pp.111-147, 1995. ,
DOI : 10.1007/BF01585555
Method for Large-Scale Optimization, Operations Research, vol.23, issue.3, pp.389-405, 1975. ,
DOI : 10.1287/opre.23.3.389
Using the primal-dual interior point algorithm within the branch-price-and-cut method, Computers & Operations Research, vol.40, issue.8, pp.2026-2036, 2013. ,
DOI : 10.1016/j.cor.2013.02.028
URL : http://dx.doi.org/10.1016/j.cor.2013.02.028
A new algorithm for the maximum-weight clique problem, Nordic Journal of Computing, vol.8, pp.424-436, 2001. ,
In-Out Separation and Column Generation Stabilization by Dual Price Smoothing, Symposium on Experimental Algorithms, pp.354-365, 2013. ,
DOI : 10.1007/978-3-642-38527-8_31
URL : https://hal.archives-ouvertes.fr/hal-00750412
Exact algorithm over an arc-time-indexed formulation for parallel machine scheduling problems, Mathematical Programming Computation, vol.4, issue.2, pp.259-290, 2010. ,
DOI : 10.1007/s12532-010-0019-z
A Minimal Algorithm for the 0-1 Knapsack Problem, Operations Research, vol.45, issue.5, pp.758-767, 1997. ,
DOI : 10.1287/opre.45.5.758
A Branch and Bound Algorithm for the Total Weighted Tardiness Problem, Operations Research, vol.33, issue.2, pp.363-377, 1985. ,
DOI : 10.1287/opre.33.2.363
Dynamical adjustment of the prox-parameter in variable metric bundle methods. Optimization, pp.423-447, 2002. ,
Solving a freight railcar flow problem arising in russia, 13th Workshop on Algorithmic Approaches for Transportation Modelling, Optimization, and Systems of OpenAccess Series in Informatics (OASIcs) Schloss Dagstuhl?Leibniz-Zentrum fuer Informatik, pp.55-67, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00857914
Implementing Mixed Integer Column Generation, Column Generation, pp.331-358, 2005. ,
DOI : 10.1007/0-387-25486-2_12
URL : https://hal.archives-ouvertes.fr/inria-00342630
A generic view of Dantzig???Wolfe decomposition in mixed integer programming, Operations Research Letters, vol.34, issue.3, pp.296-306, 2006. ,
DOI : 10.1016/j.orl.2005.05.009
URL : https://hal.archives-ouvertes.fr/inria-00342623
Extending Dantzig's bound to the bounded multiple-class binary Knapsack problem, Mathematical Programming, vol.94, issue.1, pp.125-136, 2002. ,
DOI : 10.1007/s10107-002-0300-7
Weighted dantzig?wolfe decomposition for linear mixed-integer programming, International Transactions in Operational Research, vol.4, issue.2, pp.151-162, 1997. ,
DOI : 10.1016/s0969-6016(97)00001-4
A path relinking approach with ejection chains for the generalized assignment problem, European Journal of Operational Research, vol.169, issue.2, pp.548-569, 2006. ,
DOI : 10.1016/j.ejor.2004.08.015
A backlogging model and a multi-echelon model of a dynamic economic lot size production system-a network approach, Management Science, vol.15, issue.9, pp.506-527, 1969. ,
