New interface
Conference papers
3D Cartesian Transport Sweep for Massively Parallel Architectures with PARSEC
Abstract : High-fidelity nuclear power plant core simulations require solving the Boltzmann transport equation. In discrete ordinates methods, the most computationally demanding oper-ation of this equation is the sweep operation. Considering the evolution of computer architectures, we propose in this paper, as a first step toward heterogeneous distributed architectures, a hybrid parallel implementation of the sweep operation on top of the generic task-based runtime system: PARSEC. Such an implementation targets three nested levels of parallelism: mes-sage passing, multi-threading, and vectorization. A theoretical performance model was designed to validate the approach and help the tuning of the multiple parameters involved in such an approach. The proposed parallel implementation of the Sweep achieves a sustained performance of 6.1 Tflop/s, corresponding to 33.9% of the peak performance of the targeted supercom-puter. This implementation compares favorably with state-of-art solvers such as PARTISN; and it can therefore serve as a building block for a massively parallel version of the neutron transport solver DOMINO developed at EDF.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01078362
Contributor : Mathieu Faverge Connect in order to contact the contributor
Submitted on : Tuesday, December 16, 2014 - 11:02:17 AM
Last modification on : Saturday, June 25, 2022 - 7:41:01 PM
Long-term archiving on: : Monday, March 23, 2015 - 1:44:35 PM
File
ipdps15_submitted.pdf
Identifiers
Collections
Citation
Salli Moustafa, Mathieu Faverge, Laurent Plagne, Pierre Ramet. 3D Cartesian Transport Sweep for Massively Parallel Architectures with PARSEC. IEEE International Parallel & Distributed Processing Symposium (IPDPS 2015), May 2015, Hyderabad, India. pp.581-590, ⟨10.1109/IPDPS.2015.75⟩. ⟨hal-01078362⟩
Share
Metrics
Record views
224
Files downloads
446
