Projected event-capturing time-stepping schemes for nonsmooth mechanical systems with unilateral contact and Coulomb???s friction, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.224-250, 2013. ,
DOI : 10.1016/j.cma.2012.12.012
Higher order event capturing time-stepping schemes for nonsmooth multibody systems with unilateral constraints and impacts, Applied Numerical Mathematics, vol.62, issue.10, 2011. ,
DOI : 10.1016/j.apnum.2012.06.026
URL : https://hal.archives-ouvertes.fr/inria-00476398
Numerical methods for nonsmooth dynamical systems : Inria ,
An introduction to Siconos ,
URL : https://hal.archives-ouvertes.fr/inria-00162911
A mixed formulation for frictional contact problems prone to Newton like solution methods, Computer Methods in Applied Mechanics and Engineering, vol.92, issue.3, pp.353-375, 1991. ,
DOI : 10.1016/0045-7825(91)90022-X
Numerical methods for simulation in applied dynamics, Simulation Techniques for Applied Dynamics, number 507 in CISM International Centre for Mechanical Sciences, pp.191-246, 2009. ,
DOI : 10.1007/978-3-211-89548-1_5
Non-stiff integrators for differential algebraic systems of index 2, Numerical Algorithms, vol.19, issue.1/4, pp.25-41, 1998. ,
DOI : 10.1023/A:1019123010801
Flexible Multibody Dynamics, 2010. ,
DOI : 10.1007/978-94-007-0335-3
Hem 5 user's guide, 1994. ,
Methodes demi-explicites pour equations differentielles algebraiques semi-explicites d'index 2, 1994. ,
Nonsmooth mechanics : models, dynamics and control. Communications and control engineering, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01236953
Simultaneous enforcement of constraints at position and velocity levels in the nonsmooth generalized-<mml:math altimg="si17.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>??</mml:mi></mml:math> scheme, Computer Methods in Applied Mechanics and Engineering, vol.281, pp.131-161, 2014. ,
DOI : 10.1016/j.cma.2014.07.025
A nonsmooth generalizeda scheme for flexible multibody systems with unilateral constraints, Int J Numer Meth Eng, 2013. ,
Formulation and comparison of algorithms for frictional contact problems, International Journal for Numerical Methods in Engineering, vol.34, issue.1, pp.145-173, 1998. ,
DOI : 10.1002/(SICI)1097-0207(19980515)42:1<145::AID-NME358>3.0.CO;2-L
A Time Integration Algorithm for Structural Dynamics With Improved Numerical Dissipation: The Generalized-?? Method, Journal of Applied Mechanics, vol.60, issue.2, pp.371-375, 1993. ,
DOI : 10.1115/1.2900803
Scientific computing with ordinary differential equations, volume 42 of Texts in applied mathematics, 2002. ,
A contact-stabilized Newmark method for dynamical contact problems, International Journal for Numerical Methods in Engineering, vol.1, issue.9, pp.1274-1290, 2008. ,
DOI : 10.1002/nme.2119
Time-Integration Schemes for the Finite Element Dynamic Signorini Problem, SIAM Journal on Scientific Computing, vol.33, issue.1, pp.223-249, 2011. ,
DOI : 10.1137/100791440
URL : https://hal.archives-ouvertes.fr/hal-00440128
Numerical methods in multibody dynamics, European Consortium for Mathematics in Industry. Teubner, 1998. ,
DOI : 10.1007/978-3-663-09828-7
A coupling approach for the numerical integration of non-smooth multibody systems, Proceedings of the 4th Canadian Conference on Nonlinear Solid Mechanics, pp.23-26, 2013. ,
Nonsmooth Lagrangian Mechanics and Variational Collision Integrators, SIAM Journal on Applied Dynamical Systems, vol.2, issue.3, pp.381-416, 2003. ,
DOI : 10.1137/S1111111102406038
Theorie und Numerik, volume 411 of Fortschritt-Berichte VDI : Reihe 20, Rechnerunterstützte Verfahren. VDI Verlag, Düsseldorf , als Manuskript gedruckt edition, 2007. ,
Numerical solution of differential-algebraic equations for constrained mechanical motion, Numerische Mathematik, vol.43, issue.13, pp.55-69, 1991. ,
DOI : 10.1007/BF01385770
Automatic integration of Euler-Lagrange equations with constraints, J Comput Appl Math, pp.77-90, 1985. ,
Model-based condition monitoring of an auxiliary bearing following contact events, Proceedings of MOVIC 2010, 2010. ,
Set-valued force laws in rigid body dynamics : dynamics of non-smooth systems, volume 1 of Lecture notes in applied and computational mechanics, 2001. ,
Symmetric projection methods for differential equations on manifolds, Bit Numerical Mathematics, vol.40, issue.4, pp.726-734, 2000. ,
DOI : 10.1023/A:1022344502818
Solving Ordinary Differential Equations I: Nonstiff Problems, volume 8 of Springer series in computational mathematics, 2009. ,
DOI : 10.1007/978-3-662-12607-3
Solving Ordinary Differential Equations II: Stiff and Differential- Algebraic-Problems, volume 14 of Springer series in computational mathematics, 2010. ,
Improved numerical dissipation for time integration algorithms in structural dynamics, Earthquake Engineering & Structural Dynamics, vol.7, issue.3, pp.283-292, 1977. ,
DOI : 10.1002/eqe.4290050306
Higher order integration of non-smooth dynamical systems using parallel computed extrapolation methods based on time-stepping schemes, Proceedings of 1st Inria Half-explicit timestepping schemes on velocity level based on time-discontinuous Galerkin methods 43 ,
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.235-257, 1999. ,
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
Contact Mechanics, 2008. ,
Geometric Numerical Integration of Inequality Constrained, Nonsmooth Hamiltonian Systems, SIAM Journal on Scientific Computing, vol.34, issue.5, pp.2670-2703, 2012. ,
DOI : 10.1137/100800105
Presentation and comparison of selected algorithms for dynamic contact based on the Newmark scheme, Applied Numerical Mathematics, vol.62, issue.10, pp.1393-1410, 2012. ,
DOI : 10.1016/j.apnum.2012.06.014
Computational contact and impact mechanics, 2002. ,
DOI : 10.1007/978-3-662-04864-1
Stability and convergence of mechanical systems with unilateral constraints, volume 36 of Lecture notes in applied and computational mechanics, 2008. ,
Extrapolation integrators for constrained multibody systems, IMPACT of Computing in Science and Engineering, vol.3, issue.3, pp.213-234, 1991. ,
DOI : 10.1016/0899-8248(91)90008-I
Discrete mechanics and variational integrators, Acta Numerica 2001, vol.10, pp.357-514, 2001. ,
DOI : 10.1017/S096249290100006X
Splitting methods, Acta Numerica, vol.11, issue.1, pp.341-434, 2002. ,
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.329-349, 1999. ,
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
Phem 56 user's guide, 1995. ,
Partitioned half-explicit Runge-Kutta methods for differential-algebraic systems of index 2, Computing, vol.66, issue.1, pp.43-61, 1997. ,
DOI : 10.1007/BF02684403
A method for computation for structural dynamics, J Eng Mech, vol.85, issue.3, pp.67-94, 1959. ,
A Numerical Scheme for Impact Problems I: The One-Dimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.702-733, 2002. ,
DOI : 10.1137/S0036142900378728
A Numerical Scheme for Impact Problems II: The Multidimensional Case, SIAM Journal on Numerical Analysis, vol.40, issue.2, pp.734-768, 2002. ,
DOI : 10.1137/S003614290037873X
Mechanical system dynamics, volume 40 of Lecture notes in applied and computational mechanics, 2008. ,
A Survey of Some Nonsmooth Equations and Smoothing Newton Methods, Progress in Optimization, pp.121-146, 1999. ,
DOI : 10.1007/978-1-4613-3285-5_7
Convex Analysis, 1997. ,
Timestepping schemes for nonsmooth dynamics based on discontinuous Galerkin methods: Definition and outlook, Mathematics and Computers in Simulation, vol.95, pp.180-199, 2013. ,
DOI : 10.1016/j.matcom.2012.04.012
URL : https://hal.archives-ouvertes.fr/hal-00762850
Analysing dynamical phenomenons: introduction to MBSim, Proceedings of 1st Joint International Conference on Multibody System Dynamics, pp.25-27, 2010. ,
Understanding the difference between prox and complementarity formulations for simulation of systems with contact, 2011 IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.25-30, 2011. ,
DOI : 10.1109/IROS.2011.6094779
URL : https://hal.archives-ouvertes.fr/hal-01309169
Discussion of the Gear???Gupta???Leimkuhler method for impacting mechanical systems, Multibody System Dynamics, vol.177, issue.4, pp.477-495, 2014. ,
DOI : 10.1007/s11044-013-9370-y
Computational Flexible Multibody Dynamics ,
DOI : 10.1007/978-3-642-35158-7
The discrete energy-momentum method. Conserving algorithms for nonlinear elastodynamics, ZAMP Zeitschrift f???r angewandte Mathematik und Physik, vol.33, issue.3, pp.757-792, 1992. ,
DOI : 10.1007/BF00913408
Rigid-Body Dynamics with Friction and Impact, SIAM Review, vol.42, issue.1, pp.3-39, 2000. ,
DOI : 10.1137/S0036144599360110
Dynamics with inequalities. SIAM, Philadephia, 2011. ,
Numerics of unilateral contacts and friction : modeling and numerical time integration in non-smooth dynamics, volume 47 of Lecture notes in applied and computational mechanics, 2009. ,
DOI : 10.1007/978-3-642-01100-9
Variationally consistent discretization schemes and numerical algorithms for contact problems, Acta Numerica, vol.6, issue.5, pp.569-734, 2011. ,
DOI : 10.1016/j.cma.2005.06.003
URL : https://hal.archives-ouvertes.fr/hal-01382364
Computational contact mechanics, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00466790
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
