Spoon: A Library for Implementing Analyses and Transformations of Java Source Code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software: Practice and Experience Année : 2014
This paper presents SPOON, a library for the analysis and transformation of Java source code. SPOON enables Java developers to write a large range of domain-specific analyses and transformations in an easy and concise manner. SPOON analyses and transformations are written in plain Java. With SPOON, developers do not need to dive into parsing, to hack a compiler infrastructure, or to master a new formalism.
article.pdf (612.29 Ko) Télécharger le fichier
hal-01078532 , version 1 (29-10-2014)
hal-01078532 , version 2 (12-09-2015)
  • HAL Id : hal-01078532 , version 1
Renaud Pawlak, Martin Monperrus, Nicolas Petitprez, Carlos Noguera, Lionel Seinturier. Spoon: A Library for Implementing Analyses and Transformations of Java Source Code. Software: Practice and Experience, 2014. ⟨hal-01078532v1⟩
1720 Consultations
14962 Téléchargements
