PAC Rank Elicitation through Adaptive Sampling of Stochastic Pairwise Preferences - Archive ouverte HAL Access content directly
Conference Papers Year :
We introduce the problem of PAC rank elicitation, which consists of sorting a given set of options based on adaptive sampling of stochastic pairwise preferences. More specifically, we assume the existence of a rank-ing procedure, such as Copeland's method, that deter-mines an underlying target order of the options. The goal is to predict a ranking that is sufficiently close to this target order with high probability, where closeness is measured in terms of a suitable distance measure. We instantiate this setting with combinations of two dif-ferent distance measures and ranking procedures. For these instantiations, we devise efficient strategies for sampling pairwise preferences and analyze the corre-sponding sample complexity. We also present first ex-periments to illustrate the practical performance of our methods.
aaai_2014_auth_2.pdf (467.59 Ko) Télécharger le fichier
Dates and versions
hal-01079283 , version 1 (20-11-2015)
Copyright
Identifiers
  • HAL Id : hal-01079283 , version 1
Cite
Róbert Busa-Fekete, Balázs Szörényi, Eyke Hüllermeier. PAC Rank Elicitation through Adaptive Sampling of Stochastic Pairwise Preferences. 28th AAAI Conference on Artificial Intelligence (AAAI-14), Jul 2014, Quebec City, Canada. ⟨hal-01079283⟩
298 View
163 Download
Share
