Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Dynamic optimisation of resource allocation in microorganisms: Extended abstract
Nils Giordano 1, 2 Francis Mairet 3 Jean-Luc Gouzé 3 Johannes Geiselmann 1, 2 Hidde de Jong 2, *
* Corresponding author
2 IBIS - Modeling, simulation, measurement, and control of bacterial regulatory networks
LAPM - Laboratoire Adaptation et pathogénie des micro-organismes [Grenoble], Inria Grenoble - Rhône-Alpes, Institut Jean Roget
3 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : Bacterial growth is a fundamental process in which cells sustain and reproduce themselves from available matter and energy. Optimisation principles have been widely used to explain and predict the growth behaviour of microor-ganisms, assumed to be optimized by evolution. This has given rise, among other things, to bacterial growth laws describing how the abundance of components of the gene expression machinery increases with the growth rate. These studies have mainly focused on the situation where the system is in balanced growth, a steady state in which all cell components grow at the same rate. Balanced-growth conditions, however, are far from natural growth conditions in which the environment is continually changing. We focus on the optimal allocation of resources between the gene expression machinery and other subsystems during growth-phase transitions. We describe an abstract model of the biochemical reaction processes occur-ring in the cell, based on first principles and articulated around two subsystems: the gene expression machinery and the uptake of nutrients from the environment. Using this so-called self-replicator model, we investigate the optimal dynamic reallocation of resources following a rapid change in the environment. We formulate our question as an optimal control problem that can be solved using Pontryagin's maximum principle. Preliminary results have shown the predominance of bang-singular control of resource allocation following abrupt environmental transitions.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01079299
Contributor : Nils Giordano Connect in order to contact the contributor
Submitted on : Friday, October 31, 2014 - 5:31:40 PM
Last modification on : Saturday, June 25, 2022 - 11:14:52 PM
Long-term archiving on: : Monday, February 2, 2015 - 4:47:34 PM
File
extended_abstract.pdf
Identifiers
  • HAL Id : hal-01079299, version 1
  • PRODINRA : 313933
Citation
Nils Giordano, Francis Mairet, Jean-Luc Gouzé, Johannes Geiselmann, Hidde de Jong. Dynamic optimisation of resource allocation in microorganisms: Extended abstract. 21st International Symposium on Mathematical Theory of Networks and Systems (MTNS 2014), University of Groningen. NLD., Jul 2014, Groningen, Netherlands. ⟨hal-01079299⟩
Share
Metrics
Record views
1644
Files downloads
139
