SMART: A tool for analyzing and reconciling schema matching networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract—Schema matching supports data integration by establishing correspondences between the attributes of independently designed database schemas. In recent years, various tools for automatic pair-wise matching of schemas have been developed. Since the matching process is inherently uncertain, the correspondences generated by such tools are often validated by a human expert. In this work, we consider scenarios in which attribute correspondences are identified in a network of schemas and not only in a pairwise setting. Here, correspondences between different schemas are interrelated, so that incomplete and erroneous matching results propagate in the network and the validation of a correspondence by an expert has ripple effects. To analyse and reconcile such matchings in schema networks, we present the Schema Matching Analyzer and Reconciliation Tool (SMART). It allows for the definition of network-level integrity constraints for the matching and, based thereon, detects and visualizes inconsistencies of the matching. The tool also supports the reconciliation of a matching by guiding an expert in the validation process and by offering semi-automatic conflictresolution techniques.
Fichier non déposé
hal-01079618 , version 1 (03-11-2014)
  • HAL Id : hal-01079618 , version 1
Hung Nguyen Quoc Viet, Tam Nguyen Thanh, Vinh Tuan Chau, Tri Kurniawan Wijaya, Zoltan Miklos, et al.. SMART: A tool for analyzing and reconciling schema matching networks. 31st International Conference on Data Engineering, Apr 2015, Seoul, South Korea. ⟨hal-01079618⟩
432 Consultations
0 Téléchargements
