Multivariate Normal Approximation for the Stochastic Simulation Algorithm: limit theorem and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stochastic approaches in systems biology are being used increasingly to model the heterogeneity and the intrinsic stochasticity of living systems, especially at the single-cell level. The stochastic simulation algo-rithm – also known as the Gillespie algorithm – is currently the most widely used method to simulate the time course of a system of bio-chemical reactions in a stochastic way. In this article, we present a central limit theorem for the Gillespie stochastic trajectories when the living system has reached a steady-state, that is when the internal bio-molecules concentrations are assumed to be at equilibrium. It appears that the stochastic behavior in steady-state is entirely characterized by the stoichiometry matrix of the system and a single vector of reaction probabilities. We propose several applications of this result such as deriving multivariate confidence regions for the time course of the system and a constraints-based approach which extends the flux balance analysis framework to the stochastic case.
sasb2014_picard_et_al_rev1.pdf (279.35 Ko) Télécharger le fichier
hal-01079768 , version 1 (03-11-2014)
  • HAL Id : hal-01079768 , version 1
Vincent Picard, Anne Siegel, Jérémie Bourdon. Multivariate Normal Approximation for the Stochastic Simulation Algorithm: limit theorem and applications. SASB - 5th International Workshop on Static Analysis and Systems Biology, 2014, Munchen, Germany. ⟨hal-01079768⟩
459 Consultations
233 Téléchargements
