Cost-Optimal Execution of Boolean DNF Trees with Shared Streams
Several applications process queries expressed as trees of Boolean
operators applied to predicates on sensor data streams, e.g., mobile apps
and automotive apps. Sensor data must be retrieved from the sensors, which
incurs a cost, e.g., an energy expense that depletes the battery of a mobile device, a
bandwidth usage. The objective is to determine the order in which
predicates should be evaluated so as to shortcut part of the query
evaluation and minimize the expected cost. This problem has been studied
assuming that each data stream occurs at a single predicate. In this work
we study the case in which a data stream occurs in multiple predicates,
either when each predicate references a single stream or when a predicate
can reference multiple streams. In the single-stream case we give an
optimal algorithm for a single-level tree and show that the problem is
NP-complete for DNF trees. For DNF trees we show that there exists an optimal predicate
evaluation order that is depth-first, which provides a basis for designing
a range of heuristics. In the multi-stream case we show that the problem
is NP-complete even for single-level trees. As in the single stream case,
for DNF trees we show that there exists a depth-first leaf evaluation order that is
optimal and we design efficient heuristics.
Informatique [cs]
