Fisheye Consistency: Keeping Data in Synch in a Georeplicated World
La cohérence en oeil de poisson : maintenir la synchronisation des données dans un monde géo-répliqué
Over the last thirty years, numerous consistency conditions for replicated data have been proposed and implemented. Popular examples of such conditions include linearizability (or atomicity), sequential consistency, causal consistency, and eventual consistency. These consistency conditions are usually defined independently from the computing entities (nodes) that manipulate the replicated data; i.e., they do not take into account how computing entities might be linked to one another, or geographically distributed. To address this lack, as a first contribution, this paper introduces the notion of proximity graph between computing nodes. If two nodes are connected in this graph, their operations must satisfy a strong consistency condition, while the operations invoked by other nodes are allowed to satisfy a weaker condition. The second contribution is the use of such a graph to provide a generic approach to the hybridization of data consistency conditions into the same system. We illustrate this approach on sequential consistency and causal consistency, and present a model in which all data operations are causally consistent, while operations by neighboring processes in the proximity graph are sequentially consistent. The third contribution of the paper is the design and the proof of a distributed algorithm based on this proximity graph, which combines sequential consistency and causal consistency (the resulting condition is called fisheye consistency). In doing so the paper not only extends the domain of consistency conditions, but provides a generic provably correct solution of direct relevance to modern georeplicated systems.
Au cours des trente dernières années, de nombreuses conditions de cohérence pour les données répliquées ont été proposées et mises en oeuvre. Les exemples courants de ces conditions comprennent la linéarisabilité (ou atomicité), la cohérence séquentielle, la cohérence causale, et la cohérence éventuelle. Ces conditions de cohérence sont généralement définies indépendamment des entités informatiques (noeuds) qui manipulent les données répliquées; c'est à dire qu'elles ne prennent pas en compte la façon dont les entités informatiques peuvent être liées les unes aux autres, ou géographiquement distribuées. Pour combler ce manque, ce document introduit la notion de graphe de proximité entre les noeuds de calcul d'un système réparti. Si deux noeuds sont connectés dans ce graphe, leurs activités doivent satisfaire une condition de cohérence forte, tandis que les opérations invoquées par d'autres noeuds peuvent ne satisfaire qu'une condition plus faible. Nous proposons d'utiliser un tel graphe pour fournir une approche générique à l'hybridation de conditions de cohérence des données dans un même système. Nous illustrons cette approche sur l'exemple de la cohérence séquentielle et de la cohérence causale, et présentons un modèle dans lequel, d'une part, toutes les opérations sont causalement cohérentes, et, d'autre part, les opérations par des processus qui sont voisins dans le graphe de proximité satisfont la cohérence séquentielle. Nous proposons et prouvons un algorithme distribué basé sur ce graphe de proximité, qui combine la cohérence séquentielle et la cohérence causal (nous appelons la cohérence obtenue cohérence en oeil de poisson). Ce faisant, le papier non seulement étend le domaine des conditions de cohérence, mais fournit une solution algorithmiquement correcte et générique directement applicable aux systèmes géo-répartis modernes.
