Notes on the history of reversible computation, IBM Journal of Research and Development, vol.32, issue.1, pp.16-23, 1988. ,
DOI : 10.1147/rd.321.0016
Irreversibility and Heat Generation in the Computing Process, IBM Journal of Research and Development, vol.5, issue.3, pp.183-191, 1961. ,
DOI : 10.1147/rd.53.0183
Introduction to reversible computing, Proceedings of the 2nd conference on Computing frontiers , CF '05, pp.385-390, 2005. ,
DOI : 10.1145/1062261.1062324
Reversible structures, Proceedings of the 9th International Conference on Computational Methods in Systems Biology, CMSB '11, pp.131-140, 2011. ,
DOI : 10.1145/2037509.2037529
Assembly instruction level reverse execution for debugging, ACM Transactions on Software Engineering and Methodology, vol.13, issue.2, pp.149-198, 2004. ,
DOI : 10.1145/1018210.1018211
A Functional Quantum Programming Language, 20th Annual IEEE Symposium on Logic in Computer Science (LICS' 05), pp.249-258, 2005. ,
DOI : 10.1109/LICS.2005.1
Using reversible computing to achieve fail-safety, Proceedings The Eighth International Symposium on Software Reliability Engineering, pp.182-191, 1997. ,
DOI : 10.1109/ISSRE.1997.630863
Basic concepts and taxonomy of dependable and secure computing, IEEE Transactions on Dependable and Secure Computing, vol.1, issue.1, pp.11-33, 2004. ,
DOI : 10.1109/TDSC.2004.2
Failboxes: Provably Safe Exception Handling, pp.470-494, 2009. ,
DOI : 10.1007/978-3-540-24851-4_24
A survey of rollback-recovery protocols in message-passing systems, ACM Computing Surveys, vol.34, issue.3, pp.375-408, 2002. ,
DOI : 10.1145/568522.568525
Transactional Information Systems: Theory, Algorithms, and the Practice of Concurrency Control and Recovery, 2002. ,
Reversible Communicating Systems, in: CONCUR LNCS, vol.6, issue.4, pp.292-307, 2004. ,
DOI : 10.1007/BFb0012800
URL : https://hal.archives-ouvertes.fr/hal-00784051
Reversing algebraic process calculi, The Journal of Logic and Algebraic Programming, vol.73, issue.1-2, pp.70-96, 2007. ,
DOI : 10.1016/j.jlap.2006.11.002
Communicating and mobile systems -the ?-calculus, 1999. ,
Reversing Higher-Order Pi, LNCS, vol.6269, pp.478-493, 2010. ,
DOI : 10.1007/978-3-642-15375-4_33
Bisimulation for Higher-Order Process Calculi, Information and Computation, vol.131, issue.2, pp.141-178, 1996. ,
DOI : 10.1006/inco.1996.0096
URL : https://hal.archives-ouvertes.fr/inria-00074170
Controlling Reversibility in Higher-Order Pi, LNCS, vol.6901, pp.297-311, 2011. ,
DOI : 10.1007/11539452_31
Concurrent Flexible Reversibility, 22nd European Symposium on Programming (ESOP), pp.370-390, 2013. ,
DOI : 10.1007/978-3-642-37036-6_21
URL : https://hal.archives-ouvertes.fr/hal-00811629
A Compositional Semantics for the Reversible p-Calculus, 2013 28th Annual ACM/IEEE Symposium on Logic in Computer Science, pp.388-397, 2013. ,
DOI : 10.1109/LICS.2013.45
A fully abstract semantics for causality in the ??-calculus, Acta Informatica, vol.35, issue.5, pp.353-400, 1998. ,
DOI : 10.1007/3-540-59042-0_77
A Reversible Abstract Machine and Its Space Overhead, pp.1-17, 2012. ,
DOI : 10.1007/978-3-642-30793-5_1
URL : https://hal.archives-ouvertes.fr/hal-00909384
Expressing mobility in process algebras: First-order and higher-order paradigms, 1992. ,
Back and forth bisimulations, LNCS, vol.458, pp.152-165, 1990. ,
DOI : 10.1007/BFb0039058
Generic Forward and Backward Simulations, CONCUR LNCS, vol.4137, pp.406-420, 2006. ,
DOI : 10.1007/11817949_27
A Logic with Reverse Modalities for History-preserving Bisimulations, Electronic Proceedings in Theoretical Computer Science, vol.64, pp.104-118, 2011. ,
DOI : 10.4204/EPTCS.64.8
An algebraic interpretation of the ????K-calculus; and an application of a labelled ??-calculus, Theoretical Computer Science, vol.2, issue.1, pp.97-114, 1976. ,
DOI : 10.1016/0304-3975(76)90009-8
Models for name-passing processes: interleaving and causal, Inf. Comput, vol.190, issue.2 ,
DOI : 10.1016/j.ic.2003.12.003
URL : http://doi.org/10.1016/j.ic.2003.12.003
Compositional event structure semantics for the internal pi-calculus, LNCS, vol.4703, pp.317-332, 2007. ,
Typed event structures and the linear <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-calculus, Theoretical Computer Science, vol.411, issue.19, pp.1949-1973, 2010. ,
DOI : 10.1016/j.tcs.2010.01.024
The reflexive chemical abstract machine and the join-calculus, pp.372-385, 1996. ,
The Join Calculus: A Language for Distributed Mobile Programming, LNCS, vol.2395, pp.268-332, 2000. ,
DOI : 10.1007/3-540-45699-6_6
Functions as processes, Mathematical Structures in Computer Science, vol.4, issue.02, pp.119-141, 1992. ,
DOI : 10.1016/0304-3975(87)90045-4
URL : https://hal.archives-ouvertes.fr/inria-00075405
From ?? to ??; or, Rediscovering continuations, Mathematical Structures in Computer Science, vol.9, issue.4, pp.367-401, 1999. ,
DOI : 10.1017/S0960129599002881
The Lambda Calculus ? Its Syntax and Semantics, revised Edition, 1984. ,
The M-calculus: a higher-order distributed process calculus, pp.50-61, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00072227
Normal Bisimulations in Calculi with Passivation, FOSSACS LNCS, vol.5504, pp.257-271, 2009. ,
DOI : 10.1007/978-3-540-31794-4_9
URL : https://hal.archives-ouvertes.fr/inria-00330565
Principles of Inverse Computation and the Universal Resolving Algorithm, Lecture Notes in Computer Science, vol.2566, 2002. ,
DOI : 10.1007/3-540-36377-7_13
Bidirectional transformations: A cross-discipline perspective, in: 2nd Int, Conference on Theory and Practice of Model Transformations (ICMT) Lecture Notes in Computer Science, vol.5563, 2009. ,
Combinators for bidirectional tree transformations, ACM Transactions on Programming Languages and Systems, vol.29, issue.3 ,
DOI : 10.1145/1232420.1232424
URL : https://hal.archives-ouvertes.fr/inria-00484971
Machines de turing réversibles Insolubilité récursive en n ? n de l'´ equation n = ? n , o` u ? est un " isomorphisme de codes, Comptes- Rendus Académie des Sciences, vol.257, pp.2597-2600, 1963. ,
Logical Reversibility of Computation, IBM Journal of Research and Development, vol.17, issue.6, pp.525-532, 1973. ,
DOI : 10.1147/rd.176.0525
Reversible computing and cellular automata???A survey, Theoretical Computer Science, vol.395, issue.1, pp.101-131, 2008. ,
DOI : 10.1016/j.tcs.2008.01.041
Reversible execution, Communications of the ACM, vol.16, issue.9 ,
DOI : 10.1145/362342.362360
A formal approach to undo operations in programming languages, ACM Transactions on Programming Languages and Systems, vol.8, issue.1, pp.50-87, 1986. ,
DOI : 10.1145/5001.5005
A structural approach to reversible computation, Theoretical Computer Science, vol.347, issue.3, pp.441-464, 2005. ,
DOI : 10.1016/j.tcs.2005.07.002
Reversible, irreversible and optimal ??-machines, Theoretical Computer Science, vol.227, issue.1-2, pp.79-97, 1999. ,
DOI : 10.1016/S0304-3975(99)00049-3
A Reversible SE(M)CD Machine, 11th International Workshop on Implementation of Functional Languages (IFL), no. 1868 in Lecture Notes in Computer Science, 1999. ,
DOI : 10.1007/10722298_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.8496
A Virtual Machine for Supporting Reversible Probabilistic Guarded Command Languages, Electronic Notes in Theoretical Computer Science, vol.253, issue.6 ,
DOI : 10.1016/j.entcs.2010.02.005
A reversible programming language and its invertible self-interpreter, Proceedings of the 2007 ACM SIGPLAN symposium on Partial evaluation and semantics-based program manipulation , PEPM '07, pp.144-153, 2007. ,
DOI : 10.1145/1244381.1244404
Principles of a reversible programming language, Proceedings of the 2008 conference on Computing frontiers , CF '08, pp.43-54, 2008. ,
DOI : 10.1145/1366230.1366239
Reversible Flowchart Languages and the Structured Reversible Program Theorem, LNCS, vol.5126, pp.258-270, 2008. ,
DOI : 10.1007/978-3-540-70583-3_22
An Injective Language for Reversible Computation, 7th International Conference Mathematics of Program Construction (MPC), no. 3125 in Lecture Notes in Computer Science, pp.289-313, 2004. ,
DOI : 10.1007/978-3-540-27764-4_16
Towards a Reversible Functional Language, 3rd International Workshop on Reversible Computation (RC), 2011. ,
DOI : 10.1007/978-3-642-29517-1_2
Information effects, 39th ACM SIGPLAN- SIGACT Symposium on Principles of Programming Languages (POPL), pp.73-84, 2012. ,
Formal Molecular Biology Done in CCS-R, Electronic Notes in Theoretical Computer Science, vol.180, issue.3, pp.31-49, 2007. ,
DOI : 10.1016/j.entcs.2004.01.040
A Reversible Process Calculus and the Modelling of the ERK Signalling Pathway, 4th International Workshop on Reversible Computation (RC), 2013. ,
DOI : 10.1007/978-3-642-36315-3_18
EXDAMS, Proceedings of the May 14-16, 1969, spring joint computer conference on XX, AFIPS '69 (Spring), pp.567-580, 1969. ,
DOI : 10.1145/1476793.1476881
Igor: A system for program debugging via reversible execution, Workshop on Parallel and Distributed Debugging, pp.112-123, 1988. ,
Efficient algorithms for bidirectional debugging, ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI), ACM, pp.299-310, 2000. ,
Causal-Consistent Reversible Debugging, 17th International Conference Fundamental Approaches to Software Engineering (FASE), pp.370-384, 2014. ,
DOI : 10.1007/978-3-642-54804-8_26
URL : https://hal.archives-ouvertes.fr/hal-01089270
Efficient optimistic parallel simulations using reverse computation, ACM Transactions on Modeling and Computer Simulation, vol.9, issue.3, pp.224-253, 1999. ,
DOI : 10.1145/347823.347828
Debugging Parallel Programs with Instant Replay, IEEE Transactions on Computers, vol.36, issue.4 ,
DOI : 10.1109/TC.1987.1676929
Reverse Execution of Java Bytecode, The Computer Journal, vol.45, issue.6 ,
DOI : 10.1093/comjnl/45.6.608
Time and space bounds for reversible simulation, 28th International Colloquium on Automata, Languages and Programming (ICALP), 2001. ,
Time, space, and energy in reversible computing, Proceedings of the 2nd conference on Computing frontiers , CF '05, 2005. ,
DOI : 10.1145/1062261.1062335
Proving Nondeterministically Specified Safety Properties Using Progress Measures, Information and Computation, vol.107, issue.1, pp.151-170, 1993. ,
DOI : 10.1006/inco.1993.1064
URL : http://doi.org/10.1006/inco.1993.1064
Forward and backward simulations: I. untimed systems, Inf. Comput, vol.121, issue.2 ,
Forward and backward simulations, ii: Timing-based systems, Inf. Comput, vol.128, issue.1 ,
Reversibility and asymmetric conflict in event structures, 24th International Conference on Concurrency Theory (CONCUR), 2013. ,
Reverse Bisimulations on Stable Configuration Structures, Proceedings 6th Workshop on Structural Operational Semantics (SOS), 2009. ,
DOI : 10.4204/EPTCS.18.5
Non-interleaving semantics for mobile processes, Theoretical Computer Science, vol.216, issue.1-2, pp.237-270, 1999. ,
DOI : 10.1016/S0304-3975(99)80003-6
Event Structure Semantics of Parallel Extrusion in the Pi-Calculus, 15th International Conference Foundations of Software Science and Computational Structures (FOSSACS), pp.2012-225 ,
DOI : 10.1007/978-3-642-28729-9_15
URL : https://hal.archives-ouvertes.fr/hal-00687502
