The Power of Evil Choices in Bloom Filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
A Bloom filter is a probabilistic hash-based data structure extensively used insoftware products including online security applications. This paper raises the following importantquestion: Are Bloom filters correctly designed in a security context ? The answer is no andthe reasons are multiple: bad choices of parameters, lack of adversary models and misused hashfunctions. Indeed, developers truncate cryptographic digests without a second thought on thesecurity implications.This work constructs adversary models for Bloom filters and illustrates attacks on three applica-tions, namely Scrapy web spider, Bitly Dablooms spam filter and Squid cache proxy. Conse-quently, the adversary forces the filter to systematically exhibit worst-case behavior. One of thereasons being that Bloom filter parameters are always computed in the average case. We com-pute the worst-case parameters in adversarial settings, and show how to securely and efficientlyuse cryptographic hash functions. Finally, we propose several countermeasures to mitigate ourattacks.
Informatique
RR-8627.pdf (801.51 Ko) Télécharger le fichier
hal-01082158 , version 1 (12-11-2014)
hal-01082158 , version 2 (24-02-2015)
  • HAL Id : hal-01082158 , version 1
Thomas Gerbet, Amrit Kumar, Cédric Lauradoux. The Power of Evil Choices in Bloom Filters. [Research Report] RR-8627, INRIA Grenoble. 2014. ⟨hal-01082158v1⟩
686 Consultations
2250 Téléchargements
