Uniform Stability Analysis for Time-Varying Systems Applying Homogeneity
The uniform stability notion for a class of non-linear time-varying systems is studied using the homogeneity framework. It is assumed that the system is weighted homogeneous considering the time variable as a constant parameter, then several conditions of uniform stability for such a class of systems are formulated. The results are applied to the problem of adaptive estimation for a linear system.
Automatique / Robotique
