Using Relax Operators into an MDE Security Requirement Elicitation Process for Systems of Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Systems of systems (SoS) are large-scale systems composed of complex systems with difficult to elicit and model emergent properties. One of the most significant challenges in the engineering of such systems is how to elicit their non-functional requirements such as security. In this proposal paper we introduce a Model Driven Engineering (MDE) security requirement process for SoS. It is based on the Relax language to define invariant and relaxed security requirements. This enables taking into account security concerns early in the requirements phase of the SoS. We illustrate our process on a maritime safety and security case study.
SeSos2014-VFinal.pdf (388.38 Ko) Télécharger le fichier
hal-01082400 , version 1 (20-01-2020)
  • HAL Id : hal-01082400 , version 1
Nicolas Belloir, Vanea Chiprianov, Manzoor Ahmad, Manuel Munier, Laurent Gallon, et al.. Using Relax Operators into an MDE Security Requirement Elicitation Process for Systems of Systems. ECSA 2nd International Workshop on Software Engineering for Systems-of-Systems (SESoS'2014), Aug 2014, Vienna, Austria. pp.32. ⟨hal-01082400⟩
131 Consultations
48 Téléchargements
