Large eddy simulation for incompressible flows, 2006. ,
A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Classical and variational multiscale LES of the flow around a circular cylinder on unstructured grids, Computers & Fluids, vol.39, issue.7, pp.1083-1094, 2010. ,
DOI : 10.1016/j.compfluid.2010.01.017
Variational multiscale large-eddy simulations of the flow past a circular cylinder: Reynolds number effects, Computers & Fluids, vol.47, issue.1, pp.44-50, 2011. ,
DOI : 10.1016/j.compfluid.2011.02.011
URL : https://hal.archives-ouvertes.fr/hal-00799280
Large Eddy Simulation and the variational multiscale method, Computing and Visualization in Science, vol.3, issue.1-2, pp.47-59, 2000. ,
DOI : 10.1007/s007910050051
GENERAL CIRCULATION EXPERIMENTS WITH THE PRIMITIVE EQUATIONS, Monthly Weather Review, vol.91, issue.3, pp.99-164, 1963. ,
DOI : 10.1175/1520-0493(1963)091<0099:GCEWTP>2.3.CO;2
Subgrid-scale stress modelling based on the square of the velocity gradient tensor, Flow, Turbulence and Combustion, vol.62, issue.3, pp.183-200, 1999. ,
DOI : 10.1023/A:1009995426001
URL : https://hal.archives-ouvertes.fr/hal-00910373
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, pp.1367-1383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
A dynamic subgrid???scale eddy viscosity model, Physics of Fluids A: Fluid Dynamics, vol.3, issue.7, pp.1760-1765, 1991. ,
DOI : 10.1063/1.857955
A dynamic variational multiscale method for large eddy simulations on unstructured meshes, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.13-16, pp.195-1667, 2006. ,
DOI : 10.1016/j.cma.2005.05.045
Sensitivity of the scale partition for variational multiscale large-eddy simulation of channel flow, Physics of Fluids, vol.16, issue.3, pp.824-851, 2004. ,
DOI : 10.1063/1.1644573
Variational Multiscale Large Eddy Simulation of Turbulent Flow in a Diffuser, Computational Mechanics, vol.550, issue.4, p.477495, 2012. ,
DOI : 10.1007/s00466-006-0044-y
Unstructured multigridding by volume agglomeration: Current status, Computers & Fluids, vol.21, issue.3, pp.397-433, 1992. ,
DOI : 10.1016/0045-7930(92)90047-Y
URL : https://hal.archives-ouvertes.fr/inria-00075334
A proposed modification of the Germano subgrid???scale closure method, Physics of Fluids A: Fluid Dynamics, vol.4, issue.3, pp.633-635, 1992. ,
DOI : 10.1063/1.858280
Is the dynamic procedure appropriate for all SGS model, European Conference on Computational Fluid Dynamics, pp.14-17, 2010. ,
Simulation of vortex shedding dominated flows past rigid and flexible structures, Computational Methods for Fluid-Structure Interaction, pp.1-30, 1999. ,
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-371, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
Towards the ultimate conservative scheme IV :A new approach to numerical convection, J. Comp. Phys, vol.23, pp.276-299, 1977. ,
A second order defect correction scheme for unsteady problems, Computers & Fluids, vol.25, issue.1, pp.9-27, 1996. ,
DOI : 10.1016/0045-7930(95)00027-5
URL : https://hal.archives-ouvertes.fr/inria-00074228
Flux vector splitting of the inviscid gasdynamic equations with application to finite-difference methods, Journal of Computational Physics, vol.40, issue.2, pp.263-293, 1981. ,
DOI : 10.1016/0021-9991(81)90210-2
Large eddy simulations of the flow around a circular cylinder: effects of grid resolution and subgrid scale modeling, Wind and Structures, vol.6, issue.6, pp.419-436, 2003. ,
DOI : 10.12989/was.2003.6.6.419
Unsteady turbulent vortex structure downstream of a three dimensional cylinder, J. of Thermal Science and Technology, vol.29, issue.1, pp.91-98, 2009. ,
Flow Control of Circular Cylinders with Longitudinal Grooved Surfaces, AIAA Journal, vol.40, issue.10, pp.2027-2035, 2002. ,
DOI : 10.2514/2.1535
Fundamentals of Aerodynamics, 1991. ,
Fluctuating lift on a circular cylinder: review and new measurements, Journal of Fluids and Structures, vol.17, issue.1, pp.57-96, 2003. ,
DOI : 10.1016/S0889-9746(02)00099-3
Pressure distribution around a circular cylinder in corss-flow, Proceedings of the Symposium on bluff body wakes and vortex-induce vibrations (BBVIV3), 2002. ,
The velocity field of the turbulent very near wake of a circular cylinder, Experiments in Fluids, vol.20, issue.6, pp.441-453, 1996. ,
DOI : 10.1007/BF00189383
Numerical studies of flow over a circular cylinder at ReD=3900, Physics of Fluids, vol.12, issue.2, pp.403-417, 1999. ,
DOI : 10.1063/1.870318
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Physics of Fluids, vol.20, issue.8, p.20, 2008. ,
DOI : 10.1063/1.2957018
URL : https://hal.archives-ouvertes.fr/hal-00383669
Status of Large Eddy Simulation: Results of a Workshop, Journal of Fluids Engineering, vol.119, issue.2, pp.248-262, 1997. ,
DOI : 10.1115/1.2819128
Direct numerical simulation of turbulence at lower costs, Journal of Engineering Mathematics, vol.32, issue.2/3, pp.143-159, 1997. ,
DOI : 10.1023/A:1004255329158
Regularizing turbulent flow, 2010. ,
The flapping shear layer formed by flow separation from the forward corner of a square cylinder, Journal of Fluid Mechanics, vol.173, issue.-1, pp.353-316, 1994. ,
DOI : 10.1007/BF00369117
A laser-Doppler velocimetry study of ensemble-averaged characteristics of the turbulent near wake of a square cylinder, Journal of Fluid Mechanics, vol.108, issue.-1, pp.285-319, 1995. ,
DOI : 10.1063/1.864048
Effects of incidence and afterbody shape on flow past bluff cylinders, Journal of Wind Engineering and Industrial Aerodynamics, vol.53, issue.3, pp.375-399, 1994. ,
DOI : 10.1016/0167-6105(94)90092-2
The effect of turbulence on the surface pressure field of a square prism, Journal of Fluid Mechanics, vol.23, issue.02, pp.263-282, 1975. ,
DOI : 10.1007/BF01386332
Fluctuating lift and drag on a long cylinder of square cross-section in a smooth and in a turbulent stream, Journal of Fluid Mechanics, vol.34, issue.03, pp.481-494, 1966. ,
DOI : 10.1017/S002211206600020X
