Distribution of local pressure and skin friction around a circular cylinder in cross-flow up to Re = 5 ?? 10 6, Journal of Fluid Mechanics, vol.8, issue.04, pp.625-639, 1968. ,
DOI : 10.1017/S0022112068002120
Interfacing Statistical Turbulence Closures with Large-Eddy Simulation, AIAA Journal, vol.42, issue.3, pp.485-492, 2004. ,
DOI : 10.2514/1.3496
Hybrid Simulation Approach for Cavity Flows: Blending, Algorithm, and Boundary Treatment Issues, AIAA Journal, vol.41, issue.8, pp.411463-1480, 2003. ,
DOI : 10.2514/2.2129
A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Numerical simulation of the flow around a circular cylinder at high Reynolds numbers, International Journal of Heat and Fluid Flow, vol.24, issue.4, pp.463-469, 2003. ,
DOI : 10.1016/S0142-727X(03)00061-4
An extended ??-?? finite element model, International Journal for Numerical Methods in Fluids, vol.7, issue.11, pp.1325-1345, 1992. ,
DOI : 10.1002/fld.1650141105
Temporal filtering: A consistent formalism for seamless hybrid RANS???LES modeling in inhomogeneous turbulence, International Journal of Heat and Fluid Flow, vol.31, issue.3, p.31, 2010. ,
DOI : 10.1016/j.ijheatfluidflow.2009.12.008
Hybrid largeeddy/Reynolds-averaged navier-stokes simulations of shock-separated flows, J. Spacecraft Rockets, issue.6, pp.41897-906, 2004. ,
Hybrid LES/RANS methods for the simulation of turbulent flows, Progress in Aerospace Sciences, vol.44, issue.5, pp.349-377, 2008. ,
DOI : 10.1016/j.paerosci.2008.05.001
Experimental investigations of separating boundary-layer flow from circular cylinder at reynolds numbers from 10 5 up to 10 7 ; three-dimensional vortex flow of a circular cylinder The Netherlands, Proceedings of IUTAM Symposium on One Hundred Years of Bloundary Layer Research, pp.455-462, 2006. ,
A Wall-Distance-Free k-?? Model With Enhanced Near-Wall Treatment, Journal of Fluids Engineering, vol.120, issue.3, pp.457-462, 1998. ,
DOI : 10.1115/1.2820684
On the behaviour of upwind schemes in the low Mach number limit, Computers & Fluids, vol.28, issue.1, pp.63-86, 1999. ,
DOI : 10.1016/S0045-7930(98)00017-6
URL : https://hal.archives-ouvertes.fr/hal-00871725
Surface-roughness effects on the mean flow past circular cylinders, Journal of Fluid Mechanics, vol.14, issue.04, pp.673-701, 1980. ,
DOI : 10.1016/0017-9310(77)90157-0
Turbulence. MacGraw-Hill, 1959. ,
A study of viscous cross-flow effects on circular cylinders at high Reynolds numbers, 12th Fluid and Plasma Dynamics Conference, pp.1066-1072, 1980. ,
DOI : 10.2514/6.1979-1477
Analysis and Prediction of Thin-Airfoil Stall Phenomena with Hybrid Turbulence Methodology, AIAA Journal, vol.43, issue.5, pp.953-961, 2005. ,
DOI : 10.2514/1.11672
Prediction of Unsteady Loading on a Circular Cylinder in High Reynolds Number Flows Using Large Eddy Simulation, 24th International Conference on Offshore Mechanics and Arctic Engineering: Volume 3, pp.12-16, 2005. ,
DOI : 10.1115/OMAE2005-67044
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, pp.1367-1383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
Reconstruction of Turbulent Fluctuations Using a Hybrid RANS/LES Approach, Journal of Computational Physics, vol.182, issue.1, pp.301-336, 2002. ,
DOI : 10.1006/jcph.2002.7169
URL : https://hal.archives-ouvertes.fr/tel-00006002
Numerical Investigation of High Reynolds Number Flows over Square and Circular Cylinders, Journal of Thermophysics and Heat Transfer, vol.19, issue.1, pp.72-80, 2005. ,
DOI : 10.2514/1.9195
Simulation of fluid-structure interaction in a tube array under cross flow at high reynolds numver, ERCOFTAC Bulletin, vol.86, issue.10, pp.54-59, 2011. ,
Effect of three???dimensionality on the lift and drag of nominally two???dimensional cylinders, Physics of Fluids, vol.7, issue.8, pp.1841-1865, 1995. ,
DOI : 10.1063/1.868500
Subgrid-scale stress modelling based on the square of the velocity gradient tensor. Flow Turb, Combustion, vol.62, issue.3, pp.183-200, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00910373
Les of flows around a circular cylinder in the critical reynolds number region, Proceedings of BBAA VI International Colloquium on: Bluff Bodies Aerodynamics and Applications, 2008. ,
Classical and variational multiscale LES of the flow around a circular cylinder on unstructured grids, Computers & Fluids, vol.39, issue.7, pp.1083-1094, 2010. ,
DOI : 10.1016/j.compfluid.2010.01.017
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.457.5978
Experiments on the flow past a circular cylinder at very high Reynolds number, Journal of Fluid Mechanics, vol.3, issue.03, pp.345-356, 1961. ,
DOI : 10.1017/S0022112061000950
Multiscale and multiresolution approaches in turbulence, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01313533
On the force fluctuations acting on a circular cylinder in crossflow from subcritical up to transcritical Reynolds numbers, Journal of Fluid Mechanics, vol.4, issue.-1, pp.265-285, 1983. ,
Experiments on flow past rough circular cylinders at large Reynolds numbers, Journal of Wind Engineering and Industrial Aerodynamics, vol.49, issue.1-3, pp.351-368, 1993. ,
DOI : 10.1016/0167-6105(93)90030-R
A Study of LES Models for the Simulation of a Turbulent Flow Around a Truss Spar Geometry, Volume 4: Terry Jones Pipeline Technology; Ocean Space Utilization; CFD and VIV Symposium, pp.2006-92355, 2006. ,
DOI : 10.1115/OMAE2006-92355
GENERAL CIRCULATION EXPERIMENTS WITH THE PRIMITIVE EQUATIONS, Monthly Weather Review, vol.91, issue.3, pp.99-164, 1963. ,
DOI : 10.1175/1520-0493(1963)091<0099:GCEWTP>2.3.CO;2
Advances in DNS/LES, chapter Comments on the feasibility of LES for wings and on a hybrid RANS/LES approach, 1997. ,
Hydrodynamics around cylindrical structures, World Scientific, 2006. ,
Supercritical Reynolds number simulation for two-dimensional flow over circular cylinders, Journal of Fluid Mechanics, vol.34, issue.03, pp.529-542, 1975. ,
DOI : 10.1017/S0022112075002170
Detached-eddy simulations past a circular cylinder, Flow, Turbulence and Combustion, vol.63, issue.1/4, pp.293-313, 1999. ,
DOI : 10.1023/A:1009901401183
An eddy-viscosity subgrid-scale model for turbulent shear flow: Algebraic theory and applications, Physics of Fluids, vol.16, issue.10, pp.3670-3681, 2004. ,
DOI : 10.1063/1.1785131
Experiments on mean and fluctuating pressures of circular cylinders at cross flow at very high reynolds ,
