Building detection using directional spatial constraints, IGARSS, pp.1932-1935, 2010. ,
Hierarchy in picture segmentation: a stepwise optimization approach, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.2, pp.150-163, 1989. ,
DOI : 10.1109/34.16711
Fast approximate energy minimization via graph cuts. TPAMI, IEEE Transactions on, vol.23, issue.11, pp.1222-1239, 2001. ,
DOI : 10.1109/iccv.1999.791245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
Region Merging Techniques Using Information Theory Statistical Measures, IEEE Transactions on Image Processing, vol.19, issue.6, pp.1567-1586, 2010. ,
DOI : 10.1109/TIP.2010.2043008
URL : http://upcommons.upc.edu/bitstream/2117/7488/1/getPDF.pdf
Kernel Density Estimation and Intrinsic Alignment for Shape Priors in Level Set Segmentation, International Journal of Computer Vision, vol.127, issue.2, pp.335-351, 2006. ,
DOI : 10.1007/s11263-006-7533-5
Diffusion snakes: Introducing statistical shape knowledge into the Mumford-Shah functional, International Journal of Computer Vision, vol.50, issue.3, pp.295-313, 2002. ,
DOI : 10.1023/A:1020826424915
Semiautomatic segmentation with compact shape prior, Image and Vision Computing, vol.27, issue.1-2, pp.206-219, 2009. ,
DOI : 10.1016/j.imavis.2008.02.006
Measures of the Amount of Ecologic Association Between Species, Ecology, vol.26, issue.3, pp.297-302, 1945. ,
DOI : 10.2307/1932409
Representation and detection of deformable shapes, IEEE TPAMI, vol.27, issue.2, pp.208-220, 2005. ,
Interactive Graph Cut Based Segmentation with Shape Priors, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), pp.755-762, 2005. ,
DOI : 10.1109/CVPR.2005.191
Automatic Heart Isolation for CT Coronary Visualization Using Graph-Cuts, 3rd IEEE International Symposium on Biomedical Imaging: Macro to Nano, 2006., pp.614-617, 2006. ,
DOI : 10.1109/ISBI.2006.1624991
Efficient tree searches with available algorithms, Evolutionary bioinformatics online, vol.3, p.341, 2007. ,
Convexity Shape Prior for Segmentation, ECCV, pp.675-690, 2014. ,
DOI : 10.1007/978-3-319-10602-1_44
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.638.9253
A graphical model framework for coupling MRFs and deformable models, Proceedings of the 2004 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2004. CVPR 2004., pp.739-746, 2004. ,
DOI : 10.1109/CVPR.2004.1315238
Obj cut, CVPR, pp.18-25, 2005. ,
An efficient agglomerative clustering algorithm for region growing, IAPR Workshop on Machine Vision Applications, pp.210-213, 1994. ,
Extraction of complex patterns from multiresolution remote sensing images: A hierarchical top-down methodology, Pattern Recognition, vol.45, issue.2, pp.685-706, 2012. ,
DOI : 10.1016/j.patcog.2011.07.017
Image segmentation by branch-andmincut, ECCV, pp.15-29, 2008. ,
Statistical shape influence in geodesic active contours, CVPR, pp.316-323, 2000. ,
Random tree optimization for the construction of the most parsimonious phylogenetic trees, 2009 43rd Annual Conference on Information Sciences and Systems, pp.757-762, 2009. ,
DOI : 10.1109/CISS.2009.5054819
An efficient measure of compactness for two-dimensional shapes and its application in regionalization problems, International Journal of Geographical Information Science, vol.5, issue.27, pp.1227-1250, 2013. ,
DOI : 10.1016/j.ecolmodel.2005.08.022
Binary Partition Tree for Semantic Object Extraction and Image Segmentation, IEEE Transactions on Circuits and Systems for Video Technology, vol.17, issue.3, pp.378-383, 2007. ,
DOI : 10.1109/TCSVT.2006.888943
State of the art of compactness and circularity measures, Int. Mathematical Forum, vol.4, issue.27, pp.1305-1335, 2009. ,
A Survey and Comparison of Discrete and Continuous Multi-label Optimization Approaches for the Potts Model, International Journal of Computer Vision, vol.3, issue.4, pp.223-240, 2013. ,
DOI : 10.1007/s11263-013-0619-y
A metric for distributions with applications to image databases, Sixth International Conference on Computer Vision (IEEE Cat. No.98CH36271), pp.59-66, 1998. ,
DOI : 10.1109/ICCV.1998.710701
Low-level processing of PolSAR images with binary partition trees, 2014 IEEE Geoscience and Remote Sensing Symposium, 2014. ,
DOI : 10.1109/IGARSS.2014.6946602
Binary partition tree as an efficient representation for image processing, segmentation, and information retrieval, IEEE Transactions on Image Processing, vol.9, issue.4, pp.561-576, 2000. ,
DOI : 10.1109/83.841934
Globally Optimal Image Segmentation with an Elastic Shape Prior, 2007 IEEE 11th International Conference on Computer Vision, pp.1-6, 2007. ,
DOI : 10.1109/ICCV.2007.4408972
Density estimation for statistics and data analysis, 1986. ,
Uninitialized, globally optimal, graph-based rectilinear shape segmentation-the opposing metrics method, ICCV, pp.1-8, 2007. ,
Graph cuts segmentation using an elliptical shape prior, IEEE International Conference on Image Processing 2005, p.1222, 2005. ,
DOI : 10.1109/ICIP.2005.1530282
Segmentation and classification of hyperspectral images using watershed transformation, Pattern Recognition, vol.43, issue.7, pp.2367-2379, 2010. ,
DOI : 10.1016/j.patcog.2010.01.016
URL : https://hal.archives-ouvertes.fr/hal-00578860
Improved hierarchical optimization-based classification of hyperspectral images using shape analysis, 2012 IEEE International Geoscience and Remote Sensing Symposium, pp.1409-1412, 2012. ,
DOI : 10.1109/IGARSS.2012.6351272
URL : https://hal.archives-ouvertes.fr/hal-00729038
Incorporating edge information into best merge regiongrowing segmentation, IGARSS, 2014. ,
DOI : 10.1109/igarss.2014.6947591
The rotating calipers: An efficient, multipurpose, computational tool, ICCTIM, pp.215-225, 2014. ,
Hyperspectral Image Representation and Processing With Binary Partition Trees, IEEE Transactions on Image Processing, vol.22, issue.4, pp.1430-1443, 2013. ,
DOI : 10.1109/TIP.2012.2231687
URL : https://hal.archives-ouvertes.fr/hal-00798351
Object recognition in urban hyperspectral images using Binary Partition Tree representation, 2013 IEEE International Geoscience and Remote Sensing Symposium, IGARSS, pp.4098-4101, 2013. ,
DOI : 10.1109/IGARSS.2013.6723734
Statistical learning theory, 1998. ,
Star shape prior for graph-cut image segmentation [40] Veronica Vilaplana, Ferran Marques, and Philippe Salembier. Binary partition trees for object detection, ECCV, pp.454-4672201, 2008. ,
Probability estimates for multi-class classification by pairwise coupling, JMLR, vol.5, pp.975-1005, 2004. ,
A survey of shape feature extraction techniques. Pattern recognition, pp.43-90, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00446037
