Robust control of pneumatic actuators based on a simplified model with delayed input - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— Due to frictions and air compressibility, the dy-namics of pneumatic actuators is often described by a complex fourth-order non linear model. Therefore, simplifying the model of pneumatic actuators is of prime interest to design a controller. In this paper a simple second order model is proposed by modeling the pressure dynamics with a pure time delay on the control input. The Artstein transformation is applied to this model to get a delay-free second order system. Then the delay-free system is stabilized using a robust nonlinear controller. The relevance of the proposed approach is demonstrated through experimental tests.
VSS_2014_Delay.pdf (565.9 Ko) Télécharger le fichier
hal-01084398 , version 1 (19-11-2014)
E Edjekouane, Samer Riachy, M Ghanes, Jean-Pierre Barbot. Robust control of pneumatic actuators based on a simplified model with delayed input. 13th International Workshop on Variable Structure Systems, Jun 2014, Nante, France. pp.1 - 6, ⟨10.1109/VSS.2014.6881117⟩. ⟨hal-01084398⟩
221 Consultations
171 Téléchargements
