Uniqueness results for inverse Robin problems with bounded coefficient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In this paper we address the uniqueness issue in the classical Robin inverse problem on a Lipschitz domain $\Omega\subset\RR^n$, with $L^\infty$ Robin coefficient, $L^2$ Neumann data and isotropic conductivity of class $W^{1,r}(\Omega)$, $r>n$. We show that uniqueness of the Robin coefficient on a subpart of the boundary given Cauchy data on the complementary part, does hold in dimension $n=2$ but needs not hold in higher dimension. We also raise on open issue on harmonic gradients which is of interest in this context.
BBLasoum2.pdf (339.93 Ko) Télécharger le fichier
hal-01084428 , version 1 (27-11-2014)
hal-01084428 , version 2 (11-02-2016)
Laurent Baratchart, Laurent Bourgeois, Juliette Leblond. Uniqueness results for inverse Robin problems with bounded coefficient. 2014. ⟨hal-01084428v1⟩
881 Consultations
280 Téléchargements
