Partitioned conditional generalized linear models for categorical data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In categorical data analysis, several regression models have been pro-posed for hierarchically-structured response variables, such as the nested logit model. But they have been formally defined for only two or three levels in the hierarchy. Here, we introduce the class of partitioned conditional generalized lin-ear models (PCGLMs) defined for an arbitrary number of levels. The hierarchical structure of these models is fully specified by a partition tree of categories. Using the genericity of the (r, F, Z) specification of GLMs for categorical data, PCGLMs can handle nominal, ordinal but also partially-ordered response variables.
PeyhardiTrottierGuedon2014b.pdf (472.21 Ko) Télécharger le fichier
hal-01084505 , version 1 (19-11-2014)
  • HAL Id : hal-01084505 , version 1
  • PRODINRA : 313847
Jean Peyhardi, Catherine Trottier, Yann Guédon. Partitioned conditional generalized linear models for categorical data. 29th International Workshop on Statistical Modelling (IWSM 2014), Statistical Modelling Society, Jul 2014, Göttingen, Germany. 4 p. ⟨hal-01084505⟩
370 Consultations
231 Téléchargements
