Design Space Exploration in an FPGA-Based Software Defined Radio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The FPGA (Field Programmable Gate Array) technology is expected to play a key role in the development of Software Defined Radio (SDR) platforms. To this aim, leveraging the nascent High-Level Synthesis (HLS) tools, a design flow from high-level specifications to Register-Transfer Level (RTL) description can be thought. Based on such a flow, this paper describes the Design Space Exploration (DSE) that can be achieved using loop optimizations. The mainstream objective is to demonstrate the compile-time flexibility of an architecture when associated with a reconfigurable platform. Throughout both IEEE 802.15.4 and IEEE 802.11g waveform examples, we show how the FPGA resources can be tuned according to a targeted throughput.
06927222.pdf (1.05 Mo) Télécharger le fichier
hal-01084781 , version 1 (20-11-2014)
Copyright (Tous droits réservés)
Matthieu Gautier, Ganda Stephane Ouedraogo, Olivier Sentieys. Design Space Exploration in an FPGA-Based Software Defined Radio. Euromicro Conference on Digital System Design, Aug 2014, Verona, Italy. ⟨10.1109/DSD.2014.44⟩. ⟨hal-01084781⟩
528 Consultations
354 Téléchargements
